Re: XText 2.9 and multiple grammars [message #1716591 is a reply to message #1716465] |
Sat, 05 December 2015 19:54 |
David Baum Messages: 20 Registered: August 2014 |
Junior Member |
Well, these are two projects created by the wizard + two lines added by myself, can't be so bad. Still haven't seen a working example or documentation of two xtext 2.9 grammars and maven as build system. It is hard to guess the correct configuration without any documentation, so maybe you could provide a working example?
[Updated on: Sat, 05 December 2015 19:55] Report message to a moderator
Re: XText 2.9 and multiple grammars [message #1716605 is a reply to message #1716604] |
Sun, 06 December 2015 08:50 |
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<parent>
<groupId>org.xtext.example.mydsl1</groupId>
<artifactId>org.xtext.example.mydsl1.parent</artifactId>
<version>1.0.0-SNAPSHOT</version>
</parent>
<artifactId>org.xtext.example.mydsl1</artifactId>
<packaging>jar</packaging>
<build>
<sourceDirectory>src</sourceDirectory>
<resources>
<resource>
<directory>src</directory>
<excludes>
<exclude>**/*.java</exclude>
<exclude>**/*.xtend</exclude>
<exclude>**/*.xtext</exclude>
<exclude>**/*.mwe2</exclude>
</excludes>
</resource>
</resources>
<plugins>
<plugin>
<groupId>org.codehaus.mojo</groupId>
<artifactId>exec-maven-plugin</artifactId>
<version>1.4.0</version>
<executions>
<execution>
<id>mwe2Launcher</id>
<phase>generate-sources</phase>
<goals>
<goal>java</goal>
</goals>
</execution>
</executions>
<configuration>
<mainClass>org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher</mainClass>
<arguments>
<argument>/${project.basedir}/src/org/xtext/example/mydsl1/GenerateMyDsl.mwe2</argument>
<argument>-p</argument>
<argument>rootPath=/${project.basedir}/..</argument>
</arguments>
<includePluginDependencies>true</includePluginDependencies>
<cleanupDaemonThreads>false</cleanupDaemonThreads><!-- see https://bugs.eclipse.org/bugs/show_bug.cgi?id=475098#c3 -->
</configuration>
<dependencies>
<dependency>
<groupId>org.xtext.example.mydsl</groupId>
<artifactId>org.xtext.example.mydsl</artifactId>
</dependency>
</dependencies>
</plugin>
<plugin>
<groupId>org.eclipse.xtend</groupId>
<artifactId>xtend-maven-plugin</artifactId>
</plugin>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-clean-plugin</artifactId>
<configuration>
<filesets combine.children="append">
<fileset>
<directory>${basedir}/../org.xtext.example.mydsl1/src-gen/</directory>
<includes>
<include>**/*</include>
</includes>
</fileset>
<fileset>
<directory>${basedir}/model/generated/</directory>
</fileset>
</filesets>
</configuration>
</plugin>
<plugin>
<artifactId>build-helper-maven-plugin</artifactId>
<version>1.9.1</version>
<executions>
<execution>
<id>add-source</id>
<phase>initialize</phase>
<goals>
<goal>add-source</goal>
<goal>add-resource</goal>
</goals>
<configuration>
<sources>
<source>src-gen</source>
</sources>
<resources>
<resource>
<directory>src-gen</directory>
<excludes>
<exclude>**/*.g</exclude>
</excludes>
</resource>
</resources>
</configuration>
</execution>
</executions>
</plugin>
<plugin>
<artifactId>maven-assembly-plugin</artifactId>
<version>2.5.5</version>
<configuration>
<descriptors>
<descriptor>jar-with-ecore-model.xml</descriptor>
</descriptors>
<appendAssemblyId>false</appendAssemblyId>
</configuration>
<executions>
<execution>
<id>make-assembly</id>
<phase>package</phase>
<goals>
<goal>single</goal>
</goals>
</execution>
</executions>
</plugin>
</plugins>
<pluginManagement>
<plugins>
<plugin>
<groupId>org.eclipse.m2e</groupId>
<artifactId>lifecycle-mapping</artifactId>
<version>1.0.0</version>
<configuration>
<lifecycleMappingMetadata>
<pluginExecutions>
<pluginExecution>
<pluginExecutionFilter>
<groupId>
org.codehaus.mojo
</groupId>
<artifactId>
exec-maven-plugin
</artifactId>
<versionRange>
[1.2.1,)
</versionRange>
<goals>
<goal>java</goal>
</goals>
</pluginExecutionFilter>
<action>
<ignore></ignore>
</action>
</pluginExecution>
</pluginExecutions>
</lifecycleMappingMetadata>
</configuration>
</plugin>
</plugins>
</pluginManagement>
</build>
<dependencies>
<dependency>
</dependency>
<dependency>
<groupId>org.eclipse.xtext</groupId>
<artifactId>org.eclipse.xtext</artifactId>
<version>${xtextVersion}</version>
</dependency>
<dependency>
<artifactId>org.eclipse.xtext.xbase</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.xtext.xtext</artifactId>
<optional>true</optional>
</dependency>
<dependency>
<artifactId>org.eclipse.xtext.xtext.generator</artifactId>
</dependency>
</dependencies>
</project>
module org.xtext.example.mydsl1.GenerateMyDsl
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "org.xtext.example.mydsl1"
rootPath = rootPath
code = {
encoding = "UTF-8"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = StandardLanguage {
referencedResource = "classpath:/model/generated/MyDsl.genmodel"
name = "org.xtext.example.mydsl1.MyDsl"
fileExtensions = "mydsl1"
serializer = {
generateStub = false
validator = {
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: XText 2.9 and multiple grammars [message #1719996 is a reply to message #1716680] |
Wed, 13 January 2016 16:01 |
Junior Member |
Hm, I'm still struggling with this. This grammar works with the provided solution:
grammar org.example.mygrammar
import "http://www.example.org/reused" as reusedgrammar
Now I tried this:
grammar org.example.mygrammar with org.example.reusedgrammar
This does not work, I get:
Couldn't resolve reference to Grammar 'org.example.reusedgrammar'
It is still the same mwe2 workflow with:
referencedResource = "classpath:/model/generated/Reusedgrammar.genmodel"
Do the import statement and the with statement work differently? Why the genmodel is found only in one case?
[Updated on: Wed, 13 January 2016 16:01] Report message to a moderator
FUDForum. Page generated in 0.05627 seconds
