| Eclipse and EGit: Can't export SSH [message #1715497] |
Tue, 24 November 2015 01:05  |
I tried to set up a ssh connection in order to be able to pull git repositories with EGit in Eclipse via ssh. (I'm using Eclipse Luna). For this I used instructions given on the Eclipse Wiki.
I went to Eclipse --> Windows --> Preferences --> General --> Network Connection --> SSH2 --> Key Management --> Generate RSA Key and tried to export the key via the "Export via SFTP" Button. I entered githubID@git.eclipse.org but instead of exporting my key, an error appeared on top of the window ("failed to export ssh key to remote server")
I did the whole process a few month ago (that worked) and only wanted to redo this, because pulling my repository caused an error. Old pull Error: ssh://githubID@git.eclipse.org/gitroot/myproject.git: Session.connect: java.io.IOException: End of IO Stream Read
I have read about an update of EGit and updated it as well as trying the whole process on a new laptop, but the error also occurs in the new laptop with a new Eclipse.
Does anybody knows a solution for my problem? Thank you in advance!
P.S. My Eclipse password expired a few months ago, when I was on holiday. I reset it and I'm able to login the Eclipse Homepage, but maybe I have to change my password on another platform?
FUDForum. Page generated in 0.03887 seconds
