Home » Eclipse Projects » Eclipse 4 » @PostConstruct not executed in 4.5.1(After upgrade from 4.4.1 my @PostConstruct methods don't get called anymore)
@PostConstruct not executed in 4.5.1 [message #1714557] Fri, 13 November 2015 09:23 Go to next message
A few days ago I updated from 4.4.1 to 4.5.1 but now my methods annotated with @PostConstruct are not executed anymore.
Looking at and debugging the code, I found out that my method has another instance of the PostConstruct interface in its declaredAnnotations map and therefore does not match the "if (!method.isAnnotationPresent(annotation))" check in InjectorImpl.
I then realized that my method used the javax.annotation_1.2.jar instead of the rt.jar's javax.annotation package and removed the requirement from the Manifest file but still the Object ID of the annotation on the method differs from the one used in InjectorImpl although the same package is now used.
Is there anything I am missing here? Has PostConstruct been unsupported?
Thanks for your replies
Re: @PostConstruct not executed in 4.5.1 [message #1714560 is a reply to message #1714557] Fri, 13 November 2015 09:54 Go to previous messageGo to next message
you need to import package with version constraint 1.2 in your manifest
Re: @PostConstruct not executed in 4.5.1 [message #1714562 is a reply to message #1714560] Fri, 13 November 2015 10:16 Go to previous messageGo to next message
I also tried that.
In my Dependencies tab I do not see the javax.annotation bundle unless I check "Show non-exported packages" although my osgi console lists it as RESOLVED after I start the program.
Also, when I then add it, I get a constraint violation on launch due to com.google.guava. I found a conversation that sounds like it could be the same issue: https://dev.eclipse.org/mhonarc/lists/equinox-dev/msg07890.html but unfortunately I also did not find a solution there.
Re: @PostConstruct not executed in 4.5.1 [message #1714563 is a reply to message #1714560] Fri, 13 November 2015 10:17 Go to previous messageGo to next message
Better NO version because if we once get rid of the javax.annotation
crap no change is required! The only important thing is to use a package
import for javax.annotation.
Tom
Re: @PostConstruct not executed in 4.5.1 [message #1714565 is a reply to message #1714562] Fri, 13 November 2015 10:24 Go to previous messageGo to next message
Right welcome to the fun!
As of today there's no solution to your problem if you use the e4
platform provided as is.
In e(fx)clipse we fixed the problem by providing a stub
javax.annotation.jre bundle who delegates to the JRE.
See
http://git.eclipse.org/c/efxclipse/org.eclipse.efxclipse.git/tree/bundles/runtime/javax.annotation.jre
so all e(fx)clipse users are not bitten by this crazy javax.annotation
story.
There's an bugzilla open discussing solutions but the bottom line is we
need to get rid of our javax.annotation-bundle.
Tom
On 13.11.15 16:16, quest ionnere wrote:
> I also tried that. In my Dependencies tab I do not see the
> the same issue:
Re: @PostConstruct not executed in 4.5.1 [message #1714593 is a reply to message #1714563] Fri, 13 November 2015 12:53 Go to previous messageGo to next message
Thomas Schindl wrote on Fri, 13 November 2015 16:17
Tom
Hm, of course I agree that not using the version constraint is more interesting for future development. But when I migrated my apps for the EclipseCon talk to Mars.1 I needed to add the version constraint to make it work. Without the version constraint @PostConstruct wasn't called.
Re: @PostConstruct not executed in 4.5.1 [message #1714855 is a reply to message #1714565] Tue, 17 November 2015 05:12 Go to previous messageGo to next message
Thomas Schindl wrote on Fri, 13 November 2015 15:24
Do you think the fix for e(fx)clipse should can also be used to fix my problem?
Re: @PostConstruct not executed in 4.5.1 [message #1714864 is a reply to message #1714855] Tue, 17 November 2015 06:18 Go to previous messageGo to next message
Sure - just remove javax.annotation from your target and put our
javax.annotation.jre there and you are fine.
Tom
> problem?
Re: @PostConstruct not executed in 4.5.1 [message #1714988 is a reply to message #1714864] Wed, 18 November 2015 05:59 Go to previous messageGo to next message
many thanks, that solved my issue!
Re: @PostConstruct not executed in 4.5.1 [message #1714991 is a reply to message #1714988] Wed, 18 November 2015 06:06 Go to previous message
Great you can now start removing all those crappy javax.annotation
imports ;-)
Tom
Previous Topic:Stand-alone Listener to EPartService
Next Topic:Eclipse Luna RC1 shows blank window after start.
Current Time: Mon Aug 11 17:29:17 EDT 2025
Powered by FUDForum. Page generated in 0.04229 seconds
