Home » Eclipse Projects » EGit / JGit » JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required(JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required)
JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1713626] Thu, 05 November 2015 09:54 Go to next message
I like to clone a git repository and i have to use credentials.
jgit version 4.2.0-SNAPSHOT
At linux (and Windows too), I get:
java -Dhttp.proxyHost=proxy -Dhttp.proxyPort=8080 -Dhttps.proxyHost=proxy -Dhttps.proxyPort=8080 -jar ~/jgit-cli.jar clone https://[hide]
Username for https://[hide]/info/refs?service=git-upload-pack: TheCorrectUserName
Password: TheCorrectPasswort
Cloning into 'xyz'...
org.eclipse.jgit.api.errors.TransportException:https://[hide]: 401 Authorization Required
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:140)
at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:200)
at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:134)
at org.eclipse.jgit.pgm.Clone.run(Clone.java:114)
at org.eclipse.jgit.pgm.TextBuiltin.execute(TextBuiltin.java:199)
at org.eclipse.jgit.pgm.Main.execute(Main.java:223)
at org.eclipse.jgit.pgm.Main.run(Main.java:124)
at org.eclipse.jgit.pgm.Main.main(Main.java:98)
Caused by: org.eclipse.jgit.errors.TransportException: https://[hide]: 401 Authorization Required
at org.eclipse.jgit.transport.BasePackFetchConnection.doFetch(BasePackFetchConnection.java:377)
at org.eclipse.jgit.transport.TransportHttp$SmartHttpFetchConnection.doFetch(TransportHttp.java:779)
at org.eclipse.jgit.transport.BasePackFetchConnection.fetch(BasePackFetchConnection.java:308)
at org.eclipse.jgit.transport.BasePackFetchConnection.fetch(BasePackFetchConnection.java:298)
at org.eclipse.jgit.transport.FetchProcess.fetchObjects(FetchProcess.java:245)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:161)
at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:122)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1138)
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:130)
... 7 more
at org.eclipse.jgit.transport.TransportHttp$Service.openResponse(TransportHttp.java:876)
at org.eclipse.jgit.transport.TransportHttp$MultiRequestService.execute(TransportHttp.java:977)
at org.eclipse.jgit.transport.TransportHttp$Service$HttpExecuteStream.read(TransportHttp.java:903)
at org.eclipse.jgit.util.io.UnionInputStream.read(UnionInputStream.java:145)
at org.eclipse.jgit.util.IO.readFully(IO.java:247)
at org.eclipse.jgit.transport.PacketLineIn.readLength(PacketLineIn.java:186)
at org.eclipse.jgit.transport.PacketLineIn.readString(PacketLineIn.java:138)
at org.eclipse.jgit.transport.PacketLineIn.readACK(PacketLineIn.java:102)
at org.eclipse.jgit.transport.BasePackFetchConnection.negotiate(BasePackFetchConnection.java:663)
at org.eclipse.jgit.transport.BasePackFetchConnection.doFetch(BasePackFetchConnection.java:363)
... 15 more
With git version 2.4.3 all works fine.
Can anyone give me a hint?
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1713639 is a reply to message #1713626] Thu, 05 November 2015 10:40 Go to previous messageGo to next message
Using Java 1.7 instead of 1.8:
org.eclipse.jgit.api.errors.TransportException: https://[hide]: 400 Bad Request
Caused by: org.eclipse.jgit.errors.TransportException: https://[hide]: 400 Bad Request
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:510)
at org.eclipse.jgit.transport.TransportHttp.openFetch(TransportHttp.java:296)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:136)
... 7 more
Using https://repo.eclipse.org/content/groups/releases/org/eclipse/jgit/org.eclipse.jgit.pgm/4.1.0.201509280440-r/org.eclipse.jgit.pgm-4.1.0.201509280440-r.sh
instead of the self build jgit-cli
has the same results
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1713687 is a reply to message #1713639] Thu, 05 November 2015 18:34 Go to previous messageGo to next message
I also see since a few days "401 Authorization Required" problems when pushing with JGit command line to github. Pushing works (for me) when JGit is used inside from inside Eclipse with EGit. I was hunting this down and found a problem with the java.net.Authenticator instances registered by JGit command line (when run inside Eclipse/EGit other Authenticators are installed which dont show this bug). When I remove the installation of java.net.Authenticator implementations in org.eclipse.jgit.pgm.Main everything works for me. I am still trying to find out whether simply removing Authenticator implementations will break other use cases. Maybe you could try whehter pushing from inside EGit/Eclipse helps you.
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1713688 is a reply to message #1713687] Thu, 05 November 2015 19:04 Go to previous messageGo to next message
See my proposal https://git.eclipse.org/r/59792
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1713754 is a reply to message #1713688] Fri, 06 November 2015 07:37 Go to previous messageGo to next message
addition:
with java 1.8.0_65 the error changes to:
500 Internal Server Error
going back to 1.8.0_51 it is again
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1713770 is a reply to message #1713688] Fri, 06 November 2015 10:02 Go to previous messageGo to next message
@Chris: Danke!
Thank you for the hint, I installed Eclipse Mars/EGIT before and it works. I am analysing, why EGITS log is slow comparing to git-scm command line. So I start comparing it with jgit.
The at the moment, the connection to the server is not important, i can do it with EGIT.
Nevertheless, I would like to use your changes you did in the morning. I cloned https://git.eclipse.org/r/jgit/jgit.git one hour ago, but i cannot find any changes from today, only from yesterday.
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1714137 is a reply to message #1713770] Tue, 10 November 2015 03:35 Go to previous messageGo to next message
Cloning doesn't help because my change is not yet accepted. If you follow the link https://git.eclipse.org/r/59792 you see instructions how to checkout that specific patchset. In this case the command would be
git fetch https://git.eclipse.org/r/a/jgit/jgit refs/changes/92/59792/2 && git checkout FETCH_HEAD
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1715413 is a reply to message #1714137] Mon, 23 November 2015 07:29 Go to previous messageGo to next message
Hi Chris,
Thank you for your instructions.
I am back to my environment i tried to access the repository you mentioned.
I need credentials/account to access it. How can i get them/it?
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1715420 is a reply to message #1715413] Mon, 23 November 2015 08:12 Go to previous messageGo to next message
Sorry, my fault. The url I sent contained the '.../a/..." which enforces authentication. Try this statement:
git fetch https://git.eclipse.org/r/jgit/jgit refs/changes/92/59792/2 && git checkout FETCH_HEAD
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1715433 is a reply to message #1715420] Mon, 23 November 2015 09:28 Go to previous messageGo to next message
Ok, now I build it with:
HEAD is now at 981e696... WIP: Remove installation of Authenticators from pgm.Main
Cloning with jgit-cli it, I am getting a NullPointerException before i am asked to input my credentials
at java.lang.String.<init>(String.java:166)
at org.eclipse.jgit.transport.HttpAuthMethod.authorize(HttpAuthMethod.java:222)
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:497)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1151)
at org.eclipse.jgit.pgm.Main.execute(Main.java:221)
at org.eclipse.jgit.pgm.Main.run(Main.java:122)
at org.eclipse.jgit.pgm.Main.main(Main.java:97)
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1715436 is a reply to message #1715433] Mon, 23 November 2015 09:42 Go to previous messageGo to next message
WIth
git checkout FETCH_HEAD (at the mentioned jgit repository)
i am getting the valuable information:
Jgit instead is quiet. Can i make jgit more verbose?
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1715674 is a reply to message #1715436] Wed, 25 November 2015 03:24 Go to previous messageGo to next message
Strange, it works for me. At least if I rebase the change on JGits current master. Maybe thats the problem. Here is what I am doing:
> git fetch origin
From https://git.eclipse.org/r/a/jgit/jgit
 * branch            refs/changes/92/59792/2 -> FETCH_HEAD
> git rebase origin/master
First, rewinding head to replay your work on top of it...
Applying: WIP: Remove installation of Authenticators from pgm.Main
> mvn clean install -DskipTests
> java -jar org.eclipse.jgit.pgm/target/jgit-cli.jar clone https://github.com/chalstrick/dondalfi.git /tmp/dondalfi
Cloning into '/tmp/dondalfi'...
> git -C /tmp/dondalfi/ log -3 --oneline
a52dfe5 test
56e209f modified again
d24579e modified
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1715719 is a reply to message #1715674] Wed, 25 November 2015 08:10 Go to previous messageGo to next message
I build it again (putting the proxy to the maven environment), using
instead of
still the same stack trace with my repository,
> git fetch origin
For eclipse Mars i am using EGIT (which works together with my git server). Are there differences in the implementation of between egit (with jgit) and jgit-cli, which explains the different behavior?
Eclipse Git Team Provider 4.0.0.201506090130-r org.eclipse.egit.feature.group Eclipse EGit
Java implementation of Git 4.0.0.201506090130-r org.eclipse.jgit.feature.group Eclipse JGit
I tried to build a jgit-cli version with Git 4.0.0.201506090130-r.
>git fetch origin
>git fetch https://git.eclipse.org/r/jgit/jgit v4.0.0.201506090130-r
From https://git.eclipse.org/r/jgit/jgit
* tag v4.0.0.201506090130-r -> FETCH_HEAD
Version build is: jgit version 4.2.0-SNAPSHOT
I am getting the same error/stack trace.
Can i use a typical user login for GitHub to access the test repo https://github.com/chalstrick/dondalfi.git?
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1715834 is a reply to message #1715719] Thu, 26 November 2015 08:44 Go to previous messageGo to next message
I am confused a little bit where things fail at your place. Could you configure your maven to be able to download files from the internet and the run the following commands. Please send me a trace of that:
cd /tmp
export https_proxy=proxy:8080
git clone -q https://git.eclipse.org/r/jgit/jgit
cd jgit/
git fetch https://git.eclipse.org/r/jgit/jgit refs/changes/92/59792/2 && git checkout -q FETCH_HEAD
mvn -q clean install -DskipTests
cd ..
java -Dhttps.proxyHost=proxy -Dhttps.proxyPort=8080 -jar jgit/org.eclipse.jgit.pgm/target/jgit-cli.jar clone https://github.com/chalstrick/dondalfi.git
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1715846 is a reply to message #1715834] Thu, 26 November 2015 10:14 Go to previous messageGo to next message
Hi Chris,
Sorry, i was not precise enough. My repository is user/password protected, your example is not. So the access to your repository works, see below:
D:\>mkdir \gittmp
D:\>export https_proxy=proxy:8080
D:\>cd \gittmp
D:\gittmp>git config --get core.autocrlf
true
D:\gittmp>git clone -q https://git.eclipse.org/r/jgit/jgit
D:\gittmp\jgit>git fetch https://git.eclipse.org/r/jgit/jgit refs/changes/92/59792/2
D:\gittmp\jgit>git checkout -q FETCH_HEAD
D:\gittmp\jgit>set MAVEN_OPTS= "-Dhttp.proxyHost=proxy -Dhttp.proxyPort=8080 -Dhttps.proxyHost=proxy -Dhttps.proxyPort=8080 "
D:\gittmp\jgit>mvn -q clean install -DskipTests
Warning: org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser: Property 'http://www.oracle.com/xml/jaxp/properties/entityExpansionLimit' is not recognized.
Compiler-Warnungen:
WARNING: 'org.apache.xerces.jaxp.SAXParserImpl: Property 'http://javax.xml.XMLConstants/property/accessExternalDTD' is not recognized.'
Warning: org.apache.xerces.parsers.SAXParser: Feature 'http://javax.xml.XMLConstants/feature/secure-processing' is not recognized.
Warning: org.apache.xerces.parsers.SAXParser: Property 'http://javax.xml.XMLConstants/property/accessExternalDTD' is not recognized.
Warning: org.apache.xerces.parsers.SAXParser: Property 'http://www.oracle.com/xml/jaxp/properties/entityExpansionLimit' is not recognized.
Compiler-Warnungen:
Compiler-Warnungen:
Compiler-Warnungen:
Compiler-Warnungen:
[WARNING] Map in class org.apache.maven.plugins.shade.resource.ManifestResourceTransformer declares value type as: class java.util.jar.Attributes but saw: class java.lang.String at runtime
D:\gittmp\jgit>cd ..
D:\gittmp>java -Dhttps.proxyHost=proxy -Dhttps.proxyPort=8080 -jar jgit/org.eclipse.jgit.pgm/target/jgit-cli.jar clone https://github.com/chalstrick/dondalfi.git
Cloning into 'dondalfi'...
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1716743 is a reply to message #1715846] Mon, 07 December 2015 17:35 Go to previous messageGo to next message
Could you try https://git.eclipse.org/r/#/c/62120/ ?
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1716835 is a reply to message #1716743] Tue, 08 December 2015 08:05 Go to previous messageGo to next message
Matthias Sohn wrote on Mon, 07 December 2015 22:35
Do i have to use it on top of refs/changes/92/59792/2 (https://git.eclipse.org/r/59792)?
I did it only with https://git.eclipse.org/r/#/c/62120/
D:\jgit99\>git clone https://git.eclipse.org/r/jgit/jgit
D:\jgit99\>cd jgit
D:\jgit99\jgit>git fetch https://git.eclipse.org/r/a/jgit/jgit  refs/changes/20/62120/1
D:\jgit99\jgit>git checkout FETCH_HEAD
Cloning into 'xxxxx'...
org.eclipse.jgit.api.errors.TransportException: https://yyy/git/xxxxx: 401 Authorization Required
        at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:139)
Caused by: org.eclipse.jgit.errors.TransportException: https://kazan.atosworldline.com/git/wlp-fo: 401 Authorization Required
        at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1179)
        ... 7 more
        at org.eclipse.jgit.transport.TransportHttp$Service.openResponse(TransportHttp.java:875)
        ... 15 more
Testing with git (scm): works
[Updated on: Tue, 08 December 2015 08:15] by Moderator
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1716952 is a reply to message #1716835] Wed, 09 December 2015 04:37 Go to previous messageGo to next message
Can i do something else, making some SSL/TLS connections debugging?
Debugging SSL/TLS connections
https://docs.oracle.com/javase/7/docs/technotes/guides/security/jsse/ReadDebug.html
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1717441 is a reply to message #1716952] Sun, 13 December 2015 14:22 Go to previous messageGo to next message
Try the third patchset we fixed another issue present in earlier patchsets of this change
git fetch https://git.eclipse.org/r/a/jgit/jgit refs/changes/20/62120/3 && git checkout FETCH_HEAD
We use mitmproxy [1] for debugging problems involving TLS connections
[1] http://mitmproxy.org/
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1717471 is a reply to message #1717441] Mon, 14 December 2015 04:23 Go to previous messageGo to next message
Thank you, this one works:
D:\jgit99\jgit>git fetch https://git.eclipse.org/r/jgit/jgit refs/changes/20/62120/3 & git checkout FETCH_HEAD
remote: Counting objects: 1793, done
remote: Finding sources: 100% (51/51)
emote: Total 51 (delta 14), reused 50 (delta 14)
Unpacking objects: 100% (51/51), done.
 * branch            refs/changes/20/62120/3 -> FETCH_HEAD
Warning: you are leaving 1 commit behind, not connected to
any of your branches:
  981e696 WIP: Remove installation of Authenticators from pgm.Main
If you want to keep it by creating a new branch, this may be a good time
to do so with:
 git branch <new-branch-name> 981e696
HEAD is now at bb26afe... Fix push with jgit pgm failing with "unauthorized"
Matthias Sohn wrote on Sun, 13 December 2015 19:22
Re: JGIT: org.eclipse.jgit.api.errors.TransportException: https://[hide]: 401 Authorization Required [message #1717963 is a reply to message #1717471] Fri, 18 December 2015 03:31 Go to previous message
The fix https://git.eclipse.org/r/#/c/62120/ was submitted
Previous Topic:Encryption with JGIT
Next Topic:Create Listener for Git Event using EGIT-plugins
Current Time: Mon Nov 03 22:38:48 EST 2025
Powered by FUDForum. Page generated in 0.69699 seconds
