Home » Modeling » EMF » [CDO] CDO explorer product export failing in Mars release
Re: [CDO] CDO explorer product export failing in Mars release [message #1712657 is a reply to message #1712584] |
Tue, 27 October 2015 09:21 |
Laurent Le Moux Messages: 44 Registered: June 2015 |
Member |
Hi again,
With Mars release, an org.eclipse.emf.cdo.explorer.ui plugin has been introduced.
I reproduced to previous steps importing this plugin as a source project and inializing the product file with org.eclipse.emf.cdo.explorer.ui.product.
While testing my product configuration by lauching an eclipse application, I got the following runtime exception :
Application "org.eclipse.emf.cdo.explorer.app" could not be found in the registry. The applications available are: org.eclipse.emf.cdo.explorer.ui.app, org.eclipse.emf.cdo.server.app, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error.
I specified the "org.eclipse.emf.cdo.explorer.ui.app" application in the product definition as "org.eclipse.emf.cdo.explorer.app" was in the list of choices.
I also added "org.eclipse.equinox.event" to the plugin.xml dependencies and refreshed consequently the product contents to get rid of the following error message :
Event Admin service is not available, unable to publish event org.osgi.service.event.Event
When lauching the eclipse application again, I now get an empty "CDO explorer" window showing up...
Re: [CDO] CDO explorer product export failing in Mars release [message #1712659 is a reply to message #1712657] |
Tue, 27 October 2015 09:31 |
<html>
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
</head>
Hi Laurent,<br>
<br>
The two example products "CDO Explorer" and "CDO Server" hadn't been
properly maintained for quite a while. Before MArs I noticed that
even our Buckminster build could no longer create them, so I decided
to no longer provde these two products.<br>
<br>
The CDO Explorer is really a a small set of plugins that can be
easily installed into any RCP/IDE product. <br>
<br>
An example CDO Server can now be easily installed with the Eclipse
Installer:<br>
<br>
<img src="https://www.eclipse.org/forums/index.php?t=getfile&id=23744" alt=""><br>
<br>
I hope that helps.<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
<br>
<div class="moz-cite-prefix">Am 27.10.2015 um 10:21 schrieb Laurent
Le Moux:<br>
</div>
<blockquote cite="mid:n0nfmb$mbc$1@xxxxxxxxe.org" type="cite">Hi
again,
<br>
<br>
been introduced.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
"CDO explorer" window showing up... :( </blockquote>
<br>
</body>
</html>
Attachment: dbagfacb.png
(Size: 36.92KB, Downloaded 118 times)
Cheers
/Eike
Re: [CDO] CDO explorer product export failing in Mars release [message #1712725 is a reply to message #1712683] |
Tue, 27 October 2015 17:08 |
Am 27.10.2015 um 14:27 schrieb Laurent Le Moux:
> Hi Eike,
> The CDO server product is still working fine.
> I personally find both products very useful and would suggest to maintain the possibility to run them as such... :)
Sorry, the actual product export step in the build system causes us lots of problems and we currently don't have the
resources to address them. Please see my other reply on alternative ways to create example installations.
> Concerning the explorer, I tried from scratch to run org.eclipse.emf.cdo.explorer.ui from its plugin.xml file with no
> modification and I get the empty CDO explorer showing up even if the extensions tab seems to contain all the necessary
> declarations...
> I had a fully fonctionning explorer showing up by chance once, but I do not know how, and I can not reproduce it
> anymore...
> That is the reason why I keep faith (and struggling) ;)
> Could you please give me a hint ?
I think it's as easy as putting CDO into the target platform (or the workspace) and creating a normal Eclipse
Application launch configuration. The CDO UI plugin contains an example called CDOClient1.launch. I've attached it to
this reply.
Cheers
/Eike
Cheers
/Eike
Re: [CDO] CDO explorer product export failing in Mars release [message #1714020 is a reply to message #1714015] |
Mon, 09 November 2015 12:39 |
Hi Laurent,
I see no relation between the CDOEditor and 'org.eclipse.ui.externaltools'. Maybe one of 'org.eclipse.ui.externaltools'
required bundles fixed your problem already?
Cheers
/Eike
Am 09.11.2015 um 13:25 schrieb Laurent Le Moux:
> Hi Eike,
> Sorry for my late answer. I followed your advice and managed to package a "CDO Explorer Lite" as a very simple RCP application that I can export as a standalone product.
> There's indeed nothing more to do than declare the necessary dependencies and extensions in a basic Eclipse generated RCP plugin (see attached example).
> Among the dependencies, one must of course provide the generated EMF plugin corresponding to his / her model classes.
> However, I still have a strange problem. When opening a resource (the 'security' one for instance), I get the following exception :
> java.lang.IllegalArgumentException: can't find IDadditions
> at org.eclipse.jface.action.ContributionManager.insertAfter(ContributionManager.java:324)
> at org.eclipse.jface.action.SubContributionManager.insertAfter(SubContributionManager.java:137)
> at org.eclipse.emf.cdo.internal.ui.editor.CDOActionBarContributor.contributeToMenu(CDOActionBarContributor.java:235)
> at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:169)
> at org.eclipse.emf.edit.ui.action.EditingDomainActionBarContributor.init(EditingDomainActionBarContributor.java:146)
> at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:148)
> at org.eclipse.ui.internal.EditorReference.createEditorActionBars(EditorReference.java:444)
> at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:358)
> at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:319)
> at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
> at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
> at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:879)
> at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
> at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:345)
> at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
> at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
> at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
> at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
> at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
> at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:971)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:640)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:746)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:717)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:711)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:695)
> at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:99)
> at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
> at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:186)
> at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
> at org.eclipse.swt.widgets.Display.syncExec(Display.java:4761)
> at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
> at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
> at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
> at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
> at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
> at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
> at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
> at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
> at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
> at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
> at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
> at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
> at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
> at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
> at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:494)
> at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:458)
> at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:724)
> at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:396)
> at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1166)
> at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3234)
> at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3149)
> at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3131)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3126)
> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3090)
> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3071)
> at org.eclipse.emf.cdo.ui.CDOEditorUtil$2.run(CDOEditorUtil.java:395)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
> at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4155)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3772)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
> at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at org.eclipse.emf.cdo.explorer.lite.Application.start(Application.java:20)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
> !ENTRY org.eclipse.e4.ui.workbench 4 0 2015-11-09 13:11:37.255
> !MESSAGE
> !STACK 0
> at org.eclipse.emf.cdo.internal.ui.editor.CDOEditor.dispose(CDOEditor.java:2481)
> at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.handlePartInitException(CompatibilityPart.java:288)
> at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:326)
> !ENTRY org.eclipse.ui 4 4 2015-11-09 13:11:37.257
> !MESSAGE Unable to create part
> !ENTRY org.eclipse.ui 4 0 2015-11-09 13:11:37.257
> !MESSAGE can't find IDadditions
> !ENTRY org.eclipse.e4.ui.workbench 4 2 2015-11-09 13:11:37.279
> !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench".
> !STACK 0
> at org.eclipse.emf.cdo.internal.ui.editor.CDOActionBarContributor.setActiveEditor(CDOActionBarContributor.java:289)
> at org.eclipse.ui.internal.EditorActionBars.partChanged(EditorActionBars.java:341)
> at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:301)
> at org.eclipse.ui.internal.WorkbenchPage.access$18(WorkbenchPage.java:283)
> at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:201)
> at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$3.run(PartServiceImpl.java:245)
> at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:242)
> at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:711)
> at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:639)
> at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:634)
> at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3242)
> !ENTRY org.eclipse.e4.ui.workbench 4 0 2015-11-09 13:11:37.280
> !MESSAGE An exception occurred while notifying part listeners
> !STACK 0
> Surprisingly, the problem disappears if I add 'org.eclipse.ui.externaltools' in the plugin dependencies.
> But I then get the 'run' menu displayed in my rcp application, which is not relevant.
> Is there a dependency between the 'run' menu and the 'CDO Editor' one that shows up when opening a resource ?
> Any idea how I can achieve the same behavior without having to declare 'org.eclipse.ui.externaltools' ?
> Kind regards,
> Laurent
Cheers
/Eike
Re: [CDO] CDO explorer product export failing in Mars release [message #1714481 is a reply to message #1714473] |
Fri, 13 November 2015 04:41 |
Hi Scott,
From your stack trace it looks as if your model involves EMF feature maps, which are not supported by CDO. Can you
confirm that that's the case?
Cheers
/Eike
Am 12.11.2015 um 22:40 schrieb Scott Dybiec:
> Thanks for sharing this, Laurent. I was able to get the CDO Explorer working using it. I'm using Mars.1
> Then I ran into this snag. I built the CDO server including the extended library example model plugin and when I tried
> to update the model using two different CDO Explorers, it threw this exception while adding new child objects to the
> top-level library object. I've repeated it many times, so the scenario is easy to reproduce.
> This is a legacy EMF model and hasn't been modified to be a CDO native model. It doesn't convert cleanly due some
> overridden .
> !SESSION 2015-11-12 15:58:40.973 -----------------------------------------------
> eclipse.buildId=unknown
> java.version=1.7.0_75
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
> Framework arguments: -application org.eclipse.emf.cdo.explorer.lite.application
> Command-line arguments: -application org.eclipse.emf.cdo.explorer.lite.application -data
> S:\mars-cdo-workspace/../runtime-org.eclipse.emf.cdo.explorer.lite.application -dev
> file:S:/mars-cdo-workspace/.metadata/.plugins/org.eclipse.pde.core/org.eclipse.emf.cdo.explorer.lite.application/dev.properties
> -os win32 -ws win32 -arch x86_64 -consoleLog
> !ENTRY org.eclipse.emf.common 2 0 2015-11-12 15:58:57.132
> !MESSAGE An exception was ignored during command execution
> !STACK 0
> org.eclipse.emf.common.util.WrappedException: An exception was ignored during command execution
> at org.eclipse.emf.common.command.BasicCommandStack.handleError(BasicCommandStack.java:281)
> at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:112)
> at org.eclipse.emf.edit.ui.action.StaticSelectionCommandAction.run(StaticSelectionCommandAction.java:235)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
> at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
> at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
> at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:606)
> Caused by: java.lang.ClassCastException: org.eclipse.emf.cdo.internal.common.revision.CDOFeatureMapEntryImpl cannot be
> cast to java.lang.String
> at org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl$26.doCopyValue(CDOTypeImpl.java:610)
> at org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl$26.doCopyValue(CDOTypeImpl.java:1)
> at org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl.copyValue(CDOTypeImpl.java:1021)
> at
> org.eclipse.emf.cdo.internal.common.revision.CDOListWithElementProxiesImpl.clone(CDOListWithElementProxiesImpl.java:88)
> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl.<init>(CDORevisionImpl.java:58)
> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl.copy(CDORevisionImpl.java:76)
> at org.eclipse.emf.internal.cdo.view.CDOStateMachine$WriteTransition.execute(CDOStateMachine.java:997)
> at org.eclipse.emf.internal.cdo.view.CDOStateMachine$AbstractWriteTransition.execute(CDOStateMachine.java:941)
> at org.eclipse.emf.internal.cdo.view.CDOStateMachine$WriteTransition.execute(CDOStateMachine.java:990)
> at org.eclipse.emf.internal.cdo.view.CDOStateMachine$AbstractWriteTransition.execute(CDOStateMachine.java:1)
> at org.eclipse.net4j.util.fsm.FiniteStateMachine.process(FiniteStateMachine.java:173)
> at org.eclipse.emf.internal.cdo.view.CDOStateMachine.writeWithoutViewLock(CDOStateMachine.java:354)
> at org.eclipse.emf.internal.cdo.view.CDOStateMachine.write(CDOStateMachine.java:340)
> at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.writeRevision(CDOStoreImpl.java:762)
> at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.add(CDOStoreImpl.java:491)
> at org.eclipse.emf.internal.cdo.object.CDOLegacyAdapter.notifyAdd(CDOLegacyAdapter.java:213)
> at org.eclipse.emf.internal.cdo.object.CDOLegacyAdapter.notifyChanged(CDOLegacyAdapter.java:117)
> at org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch(NotificationImpl.java:1027)
> at org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch(NotificationImpl.java:1032)
> at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllUnique(NotifyingListImpl.java:462)
> at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllUnique(NotifyingListImpl.java:400)
> at org.eclipse.emf.ecore.util.BasicFeatureMap.addAllUnique(BasicFeatureMap.java:1613)
> at org.eclipse.emf.common.util.AbstractEList.addAll(AbstractEList.java:370)
> at org.eclipse.emf.ecore.util.BasicFeatureMap.doAddAll(BasicFeatureMap.java:604)
> at org.eclipse.emf.ecore.util.BasicFeatureMap.addAll(BasicFeatureMap.java:1486)
> at org.eclipse.emf.ecore.util.FeatureMapUtil$FeatureEList.addAll(FeatureMapUtil.java:756)
> at org.eclipse.emf.edit.command.AddCommand.doExecute(AddCommand.java:399)
> at org.eclipse.emf.edit.command.AbstractOverrideableCommand.execute(AbstractOverrideableCommand.java:125)
> at org.eclipse.emf.common.command.CommandWrapper.execute(CommandWrapper.java:174)
> at org.eclipse.emf.edit.command.CreateChildCommand.execute(CreateChildCommand.java:257)
> at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
> ... 32 more
> On 11/9/2015 8:57 AM, Laurent Le Moux wrote:
>> I guess there should be no relation. However...
>> Adding 'org.eclipse.ui.externaltools' plugin dependencies to my example dependencies makes no difference.
>> Whereas declaring a minimal 'org.eclipse.ui.actionSets' extension solves the problem... (see new attachement).
Cheers
/Eike
Re: [CDO] CDO explorer product export failing in Mars release [message #1714524 is a reply to message #1714481] |
Fri, 13 November 2015 11:25 |
Scott Dybiec Messages: 148 Registered: July 2009 |
You are right, Eike. The Extended Library Model that comes as a sample
uses feature maps.
I'm excited to use CDO and fortunately my application's EMF model does
not use feature maps.
$cott
On 11/12/2015 11:41 PM, Eike Stepper wrote:
> Hi Scott,
> maps, which are not supported by CDO. Can you confirm that that's the case?
> Cheers
> /Eike
>> extended library example model plugin and when I tried to update the
>> adding new child objects to the top-level library object. I've
>> model. It doesn't convert cleanly due some overridden .
>> -dev
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> cannot be cast to java.lang.String
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 32 more
Re: [CDO] CDO explorer product export failing in Mars release [message #1714527 is a reply to message #1714524] |
Fri, 13 November 2015 12:08 |
Am 13.11.2015 um 12:25 schrieb Scott Dybiec:
> You are right, Eike. The Extended Library Model that comes as a sample uses feature maps.
We should probably add checks to detect this case (please submit a bugzilla if you feel strong about it). Formerly we
wanted to support feature maps and there's even quite some code left from those attempts. But later it turned out to be
too much effort, especially in combination with RDBs. It also had an ugly impact on the source code. So we gave up on that.
> I'm excited to use CDO and fortunately my application's EMF model does not use feature maps.
Great to hear. Have fun ;-)
Cheers
/Eike
> $cott
>> Hi Scott,
>> Cheers
>> /Eike
>>> -dev
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 32 more
Cheers
/Eike
Current Time: Fri Apr 26 03:19:13 GMT 2024
Powered by FUDForum. Page generated in 0.03575 seconds
