Home » Modeling » QVT-OML » Installing QVTo 3.5 on Eclipse Kepler
Installing QVTo 3.5 on Eclipse Kepler [message #1712548] |
Mon, 26 October 2015 10:48 |
Fon Vitale Messages: 14 Registered: November 2011 |
I'm trying to install QVTo 3.5 on Kepler. I've had to install features one by one due to QVTo SDK includes the coverage plugin which has dependencies with Eclipse UI 3.107 (kepler has Eclipse UI 3.105).
With core, runtime, debug and editor installed, I cannot create a QVTo project. That project kind does not appear in the 'New Project' wizard. In addition, Eclipse does not recognise the QVToNature nature of the project.
On the other hand, I can launch transformations with no problems.
So, have I missed something when installing QVTo?
PS: I have installed QVTo on Eclipse Mars, using QVTo SDK, and it works.
Re: Installing QVTo 3.5 on Eclipse Kepler [message #1712554 is a reply to message #1712548] |
Mon, 26 October 2015 11:16 |
Ed Willink Messages: 7670 Registered: July 2009 |
Backporting has never been a supported QVTo capability, but it should work.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=480634 raised.
It looks as if insufficient consideration was given when adding the
coverage plugins. You might find that you can just leave them out.
The QVToNature is a funny that I think I have seen. Have you restarted
Eclipse? Have you made sure that you also have a Java nature and source
folders?
Ed Willink
On 26/10/2015 10:48, Fon Mising name wrote:
> of the project.
Re: Installing QVTo 3.5 on Eclipse Kepler [message #1713053 is a reply to message #1713049] |
Fri, 30 October 2015 11:37 |
In Eclipse an X project is a project with an X nature. Natures are not
generally exclusive, so a project can be a Java+QVTo+Xtext project.
The New Project wizard gives you some helpful starters that you can
typically extend by a Configure->Add Nature menu option, or cutting and
pasting the .project file.
The example attached is a JET+Java+QVTo+Xtext+Plugin project.
The Simple UML to RDBMS example has the slightly surprising
<natures>
<nature>org.eclipse.m2m.qvt.oml.project.QVTONature</nature>
<nature>org.eclipse.pde.PluginNature</nature>
</natures>
making it a QVTo+Plugin project.
Maybe my nagging doubt about a Java nature is a red herring.
Have a look at your configuration to check whether the plugins started.
BUT: Bottom line is that you are handcrafting a non-standard unsupported
solution.
Ed Willink
On 30/10/2015 10:13, Fon Vitale wrote:
> HI Ed,
> I'm sorry, I've been very busy during the week.
> Well, trying on Eclipse Mars, the 'SimpleUML to RDB' example project
> is not a Java project. If I try to create a QVTo project (I cannot on
> Kepler due to the explanation above), the creation wizard lets me
> select the type of the project among simple project, plug-in project
> or java project. So, that makes me think that the project needs not to
> be a Java project. Am I wrong?
> Regards,
Attachment: .project
(Size: 1.32KB, Downloaded 322 times)
Re: Installing QVTo 3.5 on Eclipse Kepler [message #1713080 is a reply to message #1713053] |
Fri, 30 October 2015 16:16 |
I've downloaded the QVTo plugins into my workspace. I've realized that the plugin 'org.eclipse.m2m.qvto.oml.ui' is not added to the feature 'org.eclipse.m2m.qvt.oml.feature'. It can explain why I cannot create a QVTo project from the 'New Project' wizard. (I've checked the list of installed plugins on Eclipse Kepler and '...oml.ui' does not appear). It works by installing the plugin in dropins or plugins folder .
Thank you!
[Updated on: Fri, 30 October 2015 16:17] Report message to a moderator
Current Time: Tue Sep 24 23:03:55 GMT 2024
Powered by FUDForum. Page generated in 0.04872 seconds
