Re: CSS customization of edges? [message #1712512 is a reply to message #1712510] |
Mon, 26 October 2015 09:09 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Hi Patrik,
This is currently not supported. For edges, we support Line Width, Line Style (Plain, Dashed, Dotted...), Line Color and it is also possible to hide the decoration at the end(s) of the line (But not possible to choose a different decoration).
Edge customization is must more complicated than it is for nodes, because we need to manage the anchors, bendpoints and routing algorithms, which might need to be changed when using an image rather than a line
Camille
Camille Letavernier
Re: CSS customization of edges? [message #1712513 is a reply to message #1712510] |
Mon, 26 October 2015 09:10 |
Replacing with a shape works only for nodes. In fact, Shape replacement relies on the display of the shape in a given compartment with everything else hidden, and the edges do not have yet such compartments.
In a conceptual point of view, it is kind of hard to map the edge concept (from one source to one target for the simplest ones) to the concept of SVGs, that do not really have such source and target elements. Perhaps adding some information in the SVG, as the anchor points could be possible. The bendpoints (edge angles) would also be hard to manage in svg figures.
HTH,
Rémi
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.23354 seconds
