Re: Build but no executable [message #1712578 is a reply to message #1712573] |
Mon, 26 October 2015 15:29 |
David Vavra Messages: 1426 Registered: October 2012 |
Are the errors phantom, i.e., only those generated by the indexer and syntax analyzer? If so you can delete them in the Problems view. They will come back on the next build so it's best to figure out what's causing them then fix them. If they are real what's the point of debugging?
I have no idea why it can't find the executable at times. My guess is that it gets deleted during the build process which won't complete in the face of real errors. I don't use managed builds so can't say for sure. My make files don't clean out the executables so I have to pay attention to the build to see if there are build errors.
There's some work being done on a stand-alone debugger which may circumvent some of your problems ( https://wiki.eclipse.org/CDT/StandaloneDebugger) but that seems a rather heavy handed solution if it's a solution at all.
[Updated on: Mon, 26 October 2015 15:55] Report message to a moderator
Re: Build but no executable [message #1712622 is a reply to message #1712578] |
Mon, 26 October 2015 21:24 |
Henning Riedel Messages: 310 Registered: July 2009 |
In case your Linux (?) shows no executable:
* Did you look in the right directory?
* Is the created binary actually have executable permissions? (chmod +ux)
* Did it actually build?
If the Binary is not build?
* Did you save your files before building? There are general Eclipse
Workspace options, for building, which might be set to default values
suitable for Java or other languages, but not for C/C++.
Check the Eclipse Preferences -> General -> Workspace -> "Save
automatically before build", which will save all opened and not saved
yet files, before starting to build. Btw., I usually also have "Refresh
on Access" enabled, in case some external program changes a file, like
if the compiler creates besides an .elf file also the .map file, or a
post-process script updates the resource consumption files.
* Check the build console output. I prefer the build console, to
check the build status and if there are any failures (compile and/or
link errors). And I usually go from top to bottom. Why, because the
Problems View might sort them in different order, and sometimes, later
compile/linker errors might be due to errors in the beginning, like due
to a missing include of a header, you have none or the wrong datatype,
which can have the effect, that the compiler takes the wrong prototype
of a function.
For this, I usually enable usually in Eclipse -> Preferences -> C/C++
-> Build -> Console to "Bring the Build Console to top when building"
and set the "Limit Console output (number of lines) to the maximum
setable value in order to have the first lines still in the output window.
Am 26.10.2015 um 16:29 schrieb David Vavra:
> Are the errors real, i.e., only those generated by the indexer and
> heavy handed solution.
FUDForum. Page generated in 0.04416 seconds
