Home » Modeling » EMF » Cannot generate Model after upgrading
Cannot generate Model after upgrading [message #1711814] Mon, 19 October 2015 17:27 Go to next message
After upgrading to a later EMF version I cannot generate my model anymore.
It was working with EMF 2.8.3 (Eclipse 3.9), but not with EMF 2.11.0 (Eclipse 4.5).
The error I get is a parse error and I have traced it to be due to my DataType where I use a complex type, namely:
Instance Type Name = java.lang.Class<? extends com.example.ProductComponent>
Should I file a bug report?
Is there a workaround or a better way to do this?
Anders
[Updated on: Mon, 19 October 2015 17:27] by Moderator
Re: Cannot generate Model after upgrading [message #1711843 is a reply to message #1711814] Tue, 20 October 2015 02:17 Go to previous messageGo to next message
Anders,
I tried a data type with java.lang.Class<? extends java.lang.Object> and
experimenting discovered that using it in a multi-valued attribute produces:
public EList<Class<? extends Object>> getXs() {
if (xs == null) {
xs = new EDataTypeUniqueEList<Class<? extends
Object>>(Class<? extends Object>.class, this, ExamplePackage.X__XS);
return xs;
I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=480178 and
committed the fix.
On 19/10/2015 11:27 PM, Anders Forsell wrote:
> Hello,
> anymore.
> (Eclipse 4.5).
> Should a file a bug report?
> Anders
Re: Cannot generate Model after upgrading [message #1711844 is a reply to message #1711843] Tue, 20 October 2015 02:25 Go to previous message
Thanks Ed,
I was indeed using the type in a multi-valued attribute.
Anders
Previous Topic:Auto-completion for EMF Item property
Next Topic: [XCore] xtend-maven-plugin used with tycho don't generate sources on JENKINS
Current Time: Fri Nov 07 11:14:44 EST 2025
Powered by FUDForum. Page generated in 0.04210 seconds
