Home » Archived » Jubula » Is there a way to modify external DB Tables from within a Jubula test ?
Is there a way to modify external DB Tables from within a Jubula test ? [message #1711732] Mon, 19 October 2015 09:06 Go to next message
I'm just planning a more complex integration test with Jubula where I need to touch some interface tables of an external PostgreSQL db.
1. do I need to add an additonal JDBC driver to Jubula ?
2. is there an API for such SQL statements ?
Kind regards, Joost
Re: Is there a way to modify external DB Tables from within a Jubula test ? [message #1711736 is a reply to message #1711732] Mon, 19 October 2015 09:20 Go to previous message
Hi Joost,
since there is no API in Jubula to support DB queries you actually would have to use one of three options:
  1. Write a function (which is called when using the ? modifier in data entries) to access the DB.
  2. Write an extension which would extend something like Application and do your DB stuff in there.
  3. Wait a few weeks until direct Java method calls are available in Jubula - at least for Java based UI toolkits. You still would have to do the DB stuff on your own.
- Achim
Previous Topic:Working with Data Sets
Next Topic:How to view the contents of embedded.h2.db file
Current Time: Sun Nov 02 23:26:50 EST 2025
Powered by FUDForum. Page generated in 0.03553 seconds
