Home » Eclipse Projects » GEF » In eclipse rcp adding a new gef figure doesn't invoke selection change
In eclipse rcp adding a new gef figure doesn't invoke selection change [message #1711689] Mon, 19 October 2015 05:50 Go to next message
I am building an eclipse rcp application with the compatability layer (between version 3 and 4).
I am using GEF 3. Now when I create a new GEF figure the SelectionService of eclipse doesn't invoke handleSelectionChanged() method for some reason. The resulting bug is that actions that are supposed to be enabled due to the selection change are not enabled.
By the way, the figure appears to be selected in the GUI. The only way to invoke the selection change is to click on another GUI element and then to click back on the figure. Meaning that GEF thinks that the figure is selected.
Any ideas??
Re: In eclipse rcp adding a new gef figure doesn't invoke selection change [message #1712585 is a reply to message #1711689] Mon, 26 October 2015 11:50 Go to previous message
Can you reproduce this with any of the provided examples?
Previous Topic:[GEF4] geometry axis
Next Topic:[GEF4] FXGeometryNode bounds update
Current Time: Sat Nov 08 05:36:18 EST 2025
Powered by FUDForum. Page generated in 0.03640 seconds
