Home » Modeling » TMF (Xtext) » Xtext 2.9.0 beta - "Build system" is disabled
Xtext 2.9.0 beta - "Build system" is disabled [message #1711152] Tue, 13 October 2015 09:49 Go to next message
i'm trying to use the new Xtext project wizard which allows building projects with Maven.
I've download the latest beta release and also used update site for "bleeding edge" (at http://download.eclipse.org/modeling/tmf/xtext/updates/composite/latest/)
However, I can't select the "build system" drop down. it is always grayed out (disabled).
Has this feature developed yet? if so, how can i use it?
thanks!
Re: Xtext 2.9.0 beta - "Build system" is disabled [message #1711264 is a reply to message #1711152] Wed, 14 October 2015 08:58 Go to previous messageGo to next message
The dropdown was greyed out in Beta3. Sounds like something went wrong during your update. In Beta5/Latest, the dropdown should definitely be usable.
Re: Xtext 2.9.0 beta - "Build system" is disabled [message #1711348 is a reply to message #1711264] Thu, 15 October 2015 04:32 Go to previous message
thanks for the reply, i installed new eclipse and updated it to the latest milestone.
The drop down is working but the generated Maven projects are not working...
I have lots of problems with the Maven wizard. Sad
I guess it's still in development.
here is just one example:
[INFO] Scanning for projects...
[INFO] Computing target platform for MavenProject: org.xtext.example.mydsl:org.xtext.example.mydsl:1.0.0-SNAPSHOT @ C:\dev\xText\beta-2.9\workspace\org.xtext.example.mydsl.parent\org.xtext.example.mydsl\pom.xml
[INFO] Fetching p2.index from http://download.eclipse.org/releases/luna/201502271000/ (0B at 0B/s)
[INFO] Adding repository http://download.eclipse.org/releases/luna/201502271000
[INFO] Adding repository http://download.eclipse.org/modeling/emft/mwe/updates/releases/2.7.1
[INFO] Adding repository http://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.9.0.beta5
[ERROR] Failed to resolve target definition C:\dev\xText\beta-2.9\workspace\org.xtext.example.mydsl.parent\org.xtext.example.mydsl.target\org.xtext.example.mydsl.target.target: Failed to load p2 metadata repository from location http://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.9.0.beta5/: No repository found at http://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.9.0.beta5. -> [Help 1]
[ERROR]
Previous Topic:Automatic serialisation to XMI
Next Topic:problem with references
Current Time: Sat Sep 20 01:13:46 EDT 2025
Powered by FUDForum. Page generated in 0.04204 seconds
