Re: [CDO] No credentials provider configured [message #1710704 is a reply to message #1710699] |
Thu, 08 October 2015 14:15 |
Am 08.10.2015 um 15:41 schrieb Samuel Leisering:
> Hi
> I added an authenticator to my CDO server:
> <securityManager type="default" description="/security:annotation:home(/home)"/>
> <authenticator type="myauth"/>
The security manager includes an internal implementation of an authenticator which is backed by the security model in
the realm /security. You don't need to (and probably should not) register a separate authenticator.
Cheers
/Eike
http://www.esc-net.de
> after starting the server, it tries to create a jvm-connection with the CDO_SYSTEM user. Fails with this exteption:
> java.lang.IllegalStateException: No credentials provider configured
> at org.eclipse.net4j.signal.security.AuthenticationIndication.responding(AuthenticationIndication.java:85)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:105)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:106)
> at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:338)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:75)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:67)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:275)
> at org.eclipse.net4j.signal.Signal.run(Signal.java:154)
> at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
> at java.lang.Thread.run(Thread.java:745)
> Am i doing something wrong?
Cheers
/Eike
Re: [CDO] No credentials provider configured [message #1710773 is a reply to message #1710769] |
Fri, 09 October 2015 07:49 |
Am 09.10.2015 um 09:20 schrieb Samuel Leisering:
> Ah, i understand. There is still an issue with this however:
> I want to use the default Usermanager for organization of the users and, most importantly, the organization of
> permissions.
> Instead of the default authorization mechanism (with the passwords stored in the model) i want to connect to an ldap
> system.
> In this case I would argue that it is neccessary to use my own authenticator.
The SecurityManager implementation does currently not support authenticators other than SecurityManager.Authenticator.
When I implemented it I had no clear idea how other authenticators would play with the security manager model,
especially I have not much experience with LDAP.
Maybe you want to play with the sources, e.g., change SecurityManager.Authenticator such that it works well for your
LDAP case. I'd be happy to review a respective patch (ideally via Gerrit).
Cheers
/Eike
Cheers
/Eike
FUDForum. Page generated in 0.03210 seconds
