Home » Archived » BIRT » Changing the output file name of the report(How to change the output file name of the report template based on the parameter choosen)
Changing the output file name of the report [message #1710315] Tue, 06 October 2015 00:28 Go to next message
Dear All,
I want to know what is the process of changing the report output name in BIRT 4.5 Version.
I'm new to BIRT So, kindly help me to solve this.
Awaiting for the positive response.
Suvarnni
Re: Changing the output file name of the report [message #1710697 is a reply to message #1710315] Thu, 08 October 2015 09:17 Go to previous messageGo to next message
Here are the important lines of code:
PDFRenderOption options = new PDFRenderOption();
String outputfile = "yourName";
//this is the important line:
options.setOutputFileName(outputfile);
options.setOutputFormat("pdf");
task.setRenderOption(options);
task.run();
Re: Changing the output file name of the report [message #1732432 is a reply to message #1710697] Tue, 17 May 2016 05:57 Go to previous messageGo to next message
Where I want to enter the code?
I mean which method
Thanks In Advance
Suvarnni
Re: Changing the output file name of the report [message #1792739 is a reply to message #1710697] Mon, 23 July 2018 07:07 Go to previous message
Is is possible to use a name from a database when settings the output file name?
Previous Topic:Unable to Export BIRT report to PDF format. ERROR :- + org.eclipse.birt.report.service.api.ReportSe
Next Topic:PatternImage
Current Time: Thu Oct 16 00:20:35 EDT 2025
Powered by FUDForum. Page generated in 0.03775 seconds
