Re: Is there any easy way to remove all references to SysML from Papyrus? [message #1710184 is a reply to message #1710145] |
Mon, 05 October 2015 08:39 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Papyrus only provides one top-level feature to be installed (Except for Extras that are separated). If this top-level feature is installed, you cannot remove individual sub-features. However, if you remove the top-level feature, you can build a custom version of Papyrus by selecting only the features you need (Or, more likely, by un-selecting the features you don't need). The Eclipse installer allows you to do that via the "Group items by category" button: if it is unchecked, then all Papyrus Features will appear. There are a lot, so building a consistent product from that can be a little bit tricky, but in your case, selecting everything but SysML features should work.
HTH,
Camille
Camille Letavernier
FUDForum. Page generated in 0.03213 seconds
