Re: Any info on stable release with resolution of current bugs is gratefully received! [message #1711142 is a reply to message #1710935] |
Tue, 13 October 2015 12:37 |
As indicated in the Mars roadmap, we are still working hard on the tests and non-regressions tests on Papyrus project. We are also constantly improving the way the committers work together, so we can go for more bug reduction, as for example using the AERI tool to see which errors are found by our users.
The sequence diagram developments were kind of complex, as this diagram is a specific one (strict layout, different concept than the usual node - link / container contained relationships). We have a modernization task about sequence diagram running for Neon release, that can be also reported to Mars release if possible: 474048: [Sequence Diagram] Should be generated with latest version of generators
https://bugs.eclipse.org/bugs/show_bug.cgi?id=474048. This will give us a chance to fix lots of bugs on this diagram coming from its specific architecture.
In the meantime, we are very intereted to have some feedback from our users, and try to answer as fast as we can. Please fill free to report any bug you have on the diagrams, and check if the bugs are still present in the coming release.
Rémi
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.04101 seconds
