Home » Eclipse Projects » Eclipse 4 » Inject IEclipseContext in Service-Component
Inject IEclipseContext in Service-Component [message #1709161] Thu, 24 September 2015 10:34 Go to next message
I need to use DI in the activation method of an OSGI Service-Component. To resume the situation, see bellow my actual configuration.
APPLICATION PLUGIN (com.my.app)
First of all, I inject a custom context bean in the IEclipseContext :
public class LifeCycleManager {
	@PostContextCreate
	public void postContextCreate(IEclipseContext context) {
		// Initialize the Custom Context and set it into the Eclipse Context
               final MCustomContext customContext = PersistenceUtils.load(MCustomContext.class);
	       context.set(MCustomContext.class, customContext);
SERVICE PLUGIN (com.my.service)
Next I declare a Service-Component in the META-INF/MANIFEST.MF of my service plug-in :
Bundle-Name: Service
Bundle-SymbolicName: com.my.servicer;singleton:=true
Require-Bundle: com.my.app,
 javax. inject,
 org.apache.log4j,
 org.eclipse.e4.core.di,
 org.eclipse.e4.core.services,
 org.eclipse.e4.ui. model.workbench,
 org.eclipse.osgi.services
Service-Component: OSGI-INF/mycomponent.xml
Bundle-ActivationPolicy: lazy
Here the content OSGI-INF/mycomponent.xml :
<scr:component activate="activate" name="com.my.service">
   <implementation class="com.my.internal.MyServiceComponent"/>
   <service>
      <provide interface="com.my.service.MyService"/>
   </service>
</scr:component>
And finally, the implementation code of my component where I need the retrieve my MCustomContext :
public class MyServiceComponent implements MyService {
	@Inject
	MCustomContext customContext;
	 * Activation method
	protected void activate(ComponentContext context) {
               // this.customContext == null
Is it the right solution ? Or is it simply impossible ?
Need your help Cool
Re: Inject IEclipseContext in Service-Component [message #1709166 is a reply to message #1709161] Thu, 24 September 2015 10:52 Go to previous message
You can not use DI in an OSGi service. Dependent on your needs you either specify a referenced service if you want to stay in the OSGi world, or try to use a context function which supports access to the IEclipseContext.
http://www.vogella.com/tutorials/Eclipse4ContextFunctions/article.html
Previous Topic:How to port code using E3 ShowViewDialog to E4?
Next Topic:Initial enable status of Dynamic Menu Contribution not properly determined with sub-elements
Current Time: Sun Nov 09 21:31:36 EST 2025
Powered by FUDForum. Page generated in 0.04160 seconds
