| [CDO/Net4j] OutOfMemoryError: Direct buffer memory [message #1708868] |
Tue, 22 September 2015 01:50  |
Hi there
After running a cdo server for nearly 5 Month we got a strange exception today:
Exception in thread "net4j-Thread-1958" java.lang.OutOfMemoryError: Direct buffer memory
at java.nio.Bits.reserveMemory(Bits.java:658)
at java.nio.DirectByteBuffer.<init>(DirectByteBuffer.java:123)
at java.nio.ByteBuffer.allocateDirect(ByteBuffer.java:311)
at org.eclipse.internal.net4j.buffer.Buffer.<init>(Buffer.java:63)
at org.eclipse.internal.net4j.buffer.BufferFactory.doProvideBuffer(BufferFactory.java:37)
at org.eclipse.internal.net4j.buffer.BufferProvider.provideBuffer(BufferProvider.java:51)
at org.eclipse.internal.net4j.buffer.BufferPool.doProvideBuffer(BufferPool.java:137)
at org.eclipse.spi.net4j.Connector.provideBuffer(Connector.java:296)
at org.eclipse.spi.net4j.Channel.provideBuffer(Channel.java:243)
at org.eclipse.net4j.signal.SignalProtocol$SignalOutputStream$1.provideBuffer(SignalProtocol.java:635)
at org.eclipse.net4j.buffer.BufferOutputStream.ensureBufferPrivate(BufferOutputStream.java:209)
at org.eclipse.net4j.buffer.BufferOutputStream.write(BufferOutputStream.java:105)
at java.io.DataOutputStream.writeInt(DataOutputStream.java:197)
at org.eclipse.net4j.util.io.ExtendedDataOutput$Delegating.writeInt(ExtendedDataOutput.java:115)
at org.eclipse.emf.cdo.common.protocol.CDOProtocol$CommitNotificationInfo.write(CDOProtocol.java:96)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitNotificationRequest.requesting(CommitNotificationRequest.java:37)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerRequest.requesting(CDOServerRequest.java:50)
at org.eclipse.net4j.signal.Request.doExtendedOutput(Request.java:67)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:301)
at org.eclipse.net4j.signal.Request.doExecute(Request.java:59)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:256)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:442)
at org.eclipse.net4j.signal.Request.sendAsync(Request.java:53)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerProtocol.sendCommitNotification(CDOServerProtocol.java:177)
at org.eclipse.emf.cdo.internal.server.Session.sendCommitNotification(Session.java:462)
at org.eclipse.emf.cdo.internal.server.SessionManager.sendCommitNotification(SessionManager.java:317)
at org.eclipse.emf.cdo.internal.server.Repository.sendCommitNotification(Repository.java:913)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.sendCommitNotifications(TransactionCommitContext.java:839)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.postCommit(TransactionCommitContext.java:804)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.responding(CommitTransactionIndication.java:345)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.responding(CDOServerIndicationWithMonitoring.java:170)
at org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:93)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:66)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
[ERROR] ReportingMonitorTask failed
The server is a 64 bit Application and runs with -Xms4g -Xmx16g
Greetings,
Samuel Leisering
FUDForum. Page generated in 0.05149 seconds
