| Dali with hibernate generating tables error [message #1708852] |
Mon, 21 September 2015 17:47  |
I am trying to use hibernate with dali to generate tables from entities.
I have tried choosing Generic 2.1 as Platform and Disable Library Configuration as JPA IMplementation (I have hibernate jars in my classpath, I am using Maven).
The problem with that is that I get the error "Generate tables from Entities is not supported by the generic platform". I have previously proven that the generation works by using simple Persistence. generateSchema method and it works.
I have seen several forum entries and in one of these somebody suggested to install hibernate tools. I have installed hibernate tools 5.0 but when I tried to generate the tables I get the error:
Exception:org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:799)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:675)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:659)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:592)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(null:-2)
at sun.reflect.NativeMethodAccessorImpl.invoke(null:-1)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null:-1)
at java.lang.reflect.Method.invoke(null:-1)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
Caused by: java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:4472)
at org.eclipse.swt.SWT.error(SWT.java:4406)
at org.eclipse.swt.SWT.error(SWT.java:4377)
at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
at org.eclipse.swt.widgets.Combo.setText(Combo.java:2285)
at org.eclipse.jdt.internal.ui.wizards.dialogfields.ComboDialogField.getComboControl(ComboDialogField.java:120)
at org.eclipse.jdt.internal.ui.wizards.dialogfields.ComboDialogField.doFillIntoGrid(ComboDialogField.java:56)
at HIDDEN.HIDDEN(HIDDEN:-1)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:175)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:705)
at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:597)
at org.eclipse.jface.window.Window.create(Window.java:430)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
at org.eclipse.jface.window.Window.open(Window.java:792)
at org.eclipse.jpt.jpa.ui.internal.handlers.GenerateDDLHandler.generateDDL(GenerateDDLHandler.java:45)
at org.eclipse.jpt.jpa.ui.internal.handlers.GenerateDDLHandler.execute(GenerateDDLHandler.java:37)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at sun.reflect.GeneratedMethodAccessor89.invoke(null:-1)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
REPORT
anonymousId bd6645f2-a5c9-4c9c-9ead-0c8f87be5776
name
email
comment
eclipseBuildId 4.5.0.I20150603-2000
eclipseProduct org.eclipse.epp.package.jee.product
javaRuntimeVersion 1.8.0_51-b16
osgiWs win32
osgiOs Windows7
osgiOsVersion 6.1.0
osgiArch x86
logMessage false
ignoreSimilar false
BUNDLES
name org.eclipse.core.commands
version 3.7.0.v20150422-0725
name org.eclipse.core.databinding.observable
version 1.5.0.v20150422-0725
name org.eclipse.core.runtime
version 3.11.0.v20150405-1723
name org.eclipse.e4.core.commands
version 0.11.0.v20150422-0725
name org.eclipse.e4.core.contexts
version 1.4.0.v20150421-2214
name org.eclipse.e4.core.di
version 1.5.0.v20150421-2214
name org.eclipse.e4.ui.workbench
version 1.3.0.v20150531-1948
name org.eclipse.e4.ui.workbench.renderers.swt
version 0.13.0.v20150603-0857
name org.eclipse.e4.ui.workbench.swt
version 0.13.0.v20150504-0621
name org.eclipse.equinox.app
version 1.3.300.v20150423-1356
name org.eclipse.equinox.launcher
version 1.3.100.v20150511-1540
name org.eclipse.jdt.ui
version 3.11.0.v20150527-0925
version 3.11.0.v20150603-2000
name org.eclipse.jface
version 3.11.0.v20150602-1400
name org.eclipse.jpt.jpa.ui
version 3.4.0.v201312022017
name org.eclipse.swt
version 3.104.0.v20150528-0211
name org.eclipse.ui
version 3.107.0.v20150507-1945
name org.eclipse.ui.ide.application
version 1.1.0.v20150422-0725
version 3.11.0.v20150510-1749
name org.jboss.tools.hibernate.jpt.ui
version 5.0.0.Beta2-v20150723-1311-B28
Any help?
Thank you very much
FUDForum. Page generated in 0.03494 seconds
