EclipseLink issue in WLS 12c JPQL query compilation issue: can't be resolved to a valid type [message #1708760] |
Sun, 20 September 2015 11:04  |
We migrate some of our solution from 10.3.6 (EclipseLink 2.3.1) to 12.1.3 (EclipseLink 2.5.2) and we got an issue:
an exception occurred while executing method
javax.persistence.PersistenceException: Exception [EclipseLink-28013] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Unable to deploy PersistenceUnit [XXX] in invalid state [DeployFailed].
Internal Exception: javax.persistence.PersistenceException: Exception [EclipseLink-28019] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Deployment of PersistenceUnit [XXX] failed. Close all factories for this PersistenceUnit.
Internal Exception: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.JPQLException
Exception Description: Problem compiling ... (A select with an order by myentity.id at the end)
[224, 236] The state field path 'myentity.id;' cannot be resolved to a valid type.
The field id in my entity is declared like this:
@Id
@SequenceGenerator(name = "mySequence", sequenceName = "SEQ_ID", initialValue = 1, allocationSize = 50)
@GeneratedValue(strategy = GenerationType.SEQUENCE, generator = "mySequence")
@Column(name = "N_ID")
protected Long id;
So what's going wrong between these 2 EclipseLink versions ? a regression because I haven't this issue with WLS 10.3.6 (eg EclipseLink 2.3.1) ?
Best Regards.
FUDForum. Page generated in 0.03347 seconds
