Home » Eclipse Projects » EclipseLink » EclipseLink issue in WLS 12c JPQL query compilation issue: can't be resolved to a valid type
EclipseLink issue in WLS 12c JPQL query compilation issue: can't be resolved to a valid type [message #1708760] Sun, 20 September 2015 11:04 Go to next message
We migrate some of our solution from 10.3.6 (EclipseLink 2.3.1) to 12.1.3 (EclipseLink 2.5.2) and we got an issue:
an exception occurred while executing method
javax.persistence.PersistenceException: Exception [EclipseLink-28013] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Unable to deploy PersistenceUnit [XXX] in invalid state [DeployFailed].
Internal Exception: javax.persistence.PersistenceException: Exception [EclipseLink-28019] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Deployment of PersistenceUnit [XXX] failed. Close all factories for this PersistenceUnit.
Internal Exception: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.JPQLException
Exception Description: Problem compiling ... (A select with an order by myentity.id at the end)
[224, 236] The state field path 'myentity.id;' cannot be resolved to a valid type.
The field id in my entity is declared like this:
@Id
@SequenceGenerator(name = "mySequence", sequenceName = "SEQ_ID", initialValue = 1, allocationSize = 50)
@GeneratedValue(strategy = GenerationType.SEQUENCE, generator = "mySequence")
@Column(name = "N_ID")
protected Long id;
So what's going wrong between these 2 EclipseLink versions ? a regression because I haven't this issue with WLS 10.3.6 (eg EclipseLink 2.3.1) ?
Best Regards.
Re: EclipseLink issue in WLS 12c JPQL query compilation issue: can't be resolved to a valid type [message #1708794 is a reply to message #1708760] Mon, 21 September 2015 05:38 Go to previous messageGo to next message
Could you please provide more informstion about entity (class level annotations) and PU xml?
Re: EclipseLink issue in WLS 12c JPQL query compilation issue: can't be resolved to a valid type [message #1708799 is a reply to message #1708794] Mon, 21 September 2015 06:47 Go to previous messageGo to next message
For sure I can:
    Annotation at class level:
@Entity
@Table(name = "MY_ENTITY")
@NamedQueries({
@NamedQuery(name = XXX, query = "SELECT myentity "
+ "FROM MyEntity AS myentity WHERE ...."),
@NamedQuery(name = YYY, query = "SELECT myentity "
+ "FROM MyEntity AS myentity WHERE ....") })
@NamedNativeQuery(name = "ZZZ", query = "SELECT SEQ_XXX_ID.NEXTVAL FROM DUAL")
public class MyEntity implements Serializable {
The issue of the named query is located before the last NamedQuery in the NamedQueries list. You have to know that I have other NamedQuery where the clause myentity.id in ORDER_BY is at the end.
    PU xml:
<persistence-unit name="XXXPU"
transaction-type="JTA">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<jta-data-source>mycompagny_xa_failover.ds</jta-data-source>
<class>com.mycompagny.sss.ttt.model.MyEntity</class>
<properties>
<!-- No schema generation -->
<property name="eclipselink.ddl-generation" value="NONE" />
<property name="eclipselink.orm.validate.schema" value="true" />
<!-- Target -->
<property name="eclipselink.target-server" value="WebLogic_10" />
<property name="eclipselink.target-database" value="Oracle10g" />
<!-- logging option -->
<property name="eclipselink.logging.level" value="WARNING" />
<property name="eclipselink.logging.timestamp" value="true" />
<property name="eclipselink.logging.session" value="true" />
<property name="eclipselink.logging.thread" value="true" />
<property name="eclipselink.logging.exceptions" value="true" />
<property name="eclipselink.logging.logger" value="ServerLogger" />
<property name="eclipselink.logging.file" value="eclipselink.log" />
<property name="eclipselink.orm.throw.exceptions" value="true" />
<!-- Optimization -->
<property name="eclipselink.jdbc.native-sql" value="true" />
<property name="eclipselink.jdbc.batch-writing" value="JDBC" />
<property name="eclipselink.jdbc.fetch-size" value="25" />
<!-- <property name="eclipselink.profiler" value="PerformanceProfiler" /> -->
<!-- Cache -->
<property name="eclipselink.cache.shared.default" value="true" />
<property name="eclipselink.cache.shared.MyEntity" value="false" />
</properties>
</persistence-unit>
Best Regards.
Re: EclipseLink issue in WLS 12c JPQL query compilation issue: can't be resolved to a valid type [message #1708800 is a reply to message #1708799] Mon, 21 September 2015 06:49 Go to previous messageGo to next message
Don't forget that with the same source code I have no issue with EclipselInk 2.3.1 !
Best Regards.
Re: EclipseLink issue in WLS 12c JPQL query compilation issue: can't be resolved to a valid type [message #1709874 is a reply to message #1708760] Thu, 01 October 2015 12:04 Go to previous message
I have found the issue we have. In one of our NamedQuery, the query ends with a ;
After removing the ; it works fine.
The issue was that EclipseLink 2.3.1 doesn't detect this issue that why it worked on 10.3.6.
EclipseLink 2.5.2 is more strict when parsing the NamedQuery so that if it finds a ; at the end, it raises the exception with
Best Regards.
Previous Topic:NoSQL|Mongo : How to use ObjectID ?
Next Topic:Add custom generator re-using table generator
Current Time: Sun Mar 16 21:23:51 EDT 2025
Powered by FUDForum. Page generated in 0.30883 seconds
