Home » Newcomers » Newcomers » Eclipse hangs on "Loading Workbench" [SOLVED](eclipse/debian install problem)
Eclipse hangs on "Loading Workbench" [SOLVED] [message #1708469] Wed, 16 September 2015 16:06 Go to next message
Running debian jessie and installed Eclipse using apt-get install eclipse. Everything worked as it's supposed to.
Then tried getting the Arduino-plugin to work. Tried several versions, nightly, ... Because eclipse started freezing and not starting anymore, I had to to a reinstall a couple of times by using apt-get remove and deleting the ~/.eclipse folder.
I gave up on the plugin, but now after reinstalling eclipse it just freezes during startup.
The splash screen says "Loading Workbench" and the console says: "I: Injected update sites"
I presume that I just need to delete the right folders/files, but wouldn't know which one(s).
Can anyone help me out, please?
[Updated on: Thu, 17 September 2015 08:13] by Moderator
Re: Eclipse hangs on "Loading Workbench" [message #1708551 is a reply to message #1708469] Thu, 17 September 2015 08:11 Go to previous messageGo to next message
Did an extensive find / -name '*eclipse*' and deleted everything. Everything is back up and running.
Re: Eclipse hangs on "Loading Workbench" [message #1708561 is a reply to message #1708551] Thu, 17 September 2015 09:06 Go to previous message
For future reference, don't install Eclipse from any Linux package manager/repository - always just download from https://www.eclipse.org/downloads/ . You'll save yourself a lot of headaches.
Previous Topic:JVM not suitable
Next Topic:japanese support on eclipse CDT
Current Time: Fri Sep 26 12:11:10 EDT 2025
Powered by FUDForum. Page generated in 0.07311 seconds
