Re: Running into errors [message #1707703 is a reply to message #1707590] |
Tue, 08 September 2015 14:59 |
David Vavra Messages: 1426 Registered: October 2012 |
"/media/christian/USB30FD/Comp222/Comp222 Workspace/C book problems/Debug/C book problems" looks like a directory name instead of an executable name.
What do you mean by " try to run"?
Are you running the programs from Eclipse or trying to?
If so, create a launcher for each executable. They are in project properties ==> Run/Debug Settings but you can also access them with the selectors next to the Debug and Run icons. One of these launchers is what you should be running.
If not, how are you starting the program?
[Updated on: Tue, 08 September 2015 15:03] Report message to a moderator
FUDForum. Page generated in 0.02989 seconds
