| Integrating into Eclipse e4 application [message #1707479] |
Sat, 05 September 2015 02:13  |
i have a pure Eclipse e4 application. I wanted to integrate my DSL into the application. All needed plugins are loaded and the plugin for my own dsl is also loaded.
Now I am trying to read a DSL file and get the AST for it. But the problem already starts with "How to get a parser instance?". I tried the approach from the FAQ.
StandaloneSetup standaloneSetup = new StandaloneSetup();
// standaloneSetup.setPlatformUri(Platform.getInstallLocation().getURL().getPath());
standaloneSetup.setPlatformUri("/home/mihael/devel/workspace-dsl/");
Injector injector = new CLStandaloneSetupGenerated().createInjectorAndDoEMFRegistration();
resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
But to what should the platform URI be set?
No matter what I do the content type to factory map from the resource set is always empty (and it probably shouldn't be?).
Any attempt to parse a file results in
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Content ist nicht zulässig in Prolog.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:195)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at miworkplace.ui.editor.cl.ClEditor.buildAst(ClEditor.java:113)
at miworkplace.ui.editor.cl.ClEditor.receiveDocument(ClEditor.java:106)
at miworkplace.ui.editor.SourceContentLoader.run(SourceContentLoader.java:94)
at miworkplace.ui.editor.RemoteEditor.load(RemoteEditor.java:459)
at miworkplace.ui.explorer.api.AbstractOpenHandler.open(AbstractOpenHandler.java:139)
at miworkplace.ui.explorer.api.AbstractOpenHandler.open(AbstractOpenHandler.java:41)
at miworkplace.ui.editor.cl.handler.OpenWithClEditorHandler.execute(OpenWithClEditorHandler.java:50)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:247)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:229)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:149)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:196)
at miworkplace.ui.SourceMemberDoubleClickProvider.execute(SourceMemberDoubleClickProvider.java:85)
at miworkplace.ui.explorer.QsysViewer$2.doubleClick(QsysViewer.java:126)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:831)
at org.eclipse.jface.util.SafeRunnable$1.run(SafeRunnable.java:131)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:178)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:828)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1472)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1237)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:252)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:311)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4454)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1388)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3799)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3409)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:164)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: org.xml.sax.SAXParseExceptionpublicId: remotefile://VGVzdA==/QSYS.LIB/MSCHMIDT.LIB/SOURCES.FILE/INSTALL.MBR.cl; systemId: remotefile://VGVzdA==/QSYS.LIB/MSCHMIDT.LIB/SOURCES.FILE/INSTALL.MBR.cl; lineNumber: 1; columnNumber: 1; Content ist nicht zulässig in Prolog.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:198)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:441)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:368)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1437)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:999)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:648)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:332)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 57 more
Seems to me it uses a default parser which of course doesn't work.
Any help is appreciated.
Thanx
Mihael
FUDForum. Page generated in 0.03817 seconds
