Re: missing RULE_BEGIN if using whitespace-aware [message #1707410 is a reply to message #1707407] |
Fri, 04 September 2015 14:42 |
Peter Vanusanik Messages: 7 Registered: June 2015 |
Christian Dietrich wrote on Fri, 04 September 2015 14:11(the problematic point is org.eclipse.xtext.parser.antlr.AbstractIndentationTokenSource.computeIndentation(String)
protected int computeIndentation(String text) {
int result = 0;
for(int i = text.length() - 1; i>=0; i--) {
char c = text.charAt(i);
if (c == '\n' || c == '\r') {
return result;
if (c == '\t') {
result+=getTabWidth();
} else {
result++;
return -1;
Is what I have in that class.
Is that a bug in the xtext? If so, can I fix it and inject the correct one?
[Updated on: Fri, 04 September 2015 14:46] Report message to a moderator
Re: missing RULE_BEGIN if using whitespace-aware [message #1707444 is a reply to message #1707442] |
Fri, 04 September 2015 18:11 |
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TMF&component=Xtext
the following works for me ?!?
grammar org.xtext.example.mydsl3.MyDsl hidden (WS, SL_COMMENT)
generate myDsl "http://www.xtext.org/example/mydsl3/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
file_input:
{file_input}
( los+=stmt )*
if_stmt:
'if' tests+=test ':' suite+=suite
test:
value="true" | value="false"
suite:
simple_stmt=suiteblock
suiteblock:
BEGIN
stmts+=stmt+
END
stmt:
print_stmt | if_stmt
print_stmt:
PRINT vlaue=STRING
terminal BEGIN: 'synthetic:BEGIN';
terminal END: 'synthetic:END';
terminal PRINT: 'print';
terminal STRING:
'"' ( '\\' . /* ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') */ | !('\\'|'"') )* '"'? |
"'" ( '\\' . /* ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') */ | !('\\'|"'") )* "'"? |
terminal SL_COMMENT: '#' !('\n'|'\r')* ('\r'? '\n')?;
terminal WS: ('\r'|'\n'|'\t'|' ')+;
if true:
print "x"
print "x"
print "y"
Twitter : @chrdietrich
Re: missing RULE_BEGIN if using whitespace-aware [message #1707447 is a reply to message #1707444] |
Fri, 04 September 2015 18:34 |
Christian Dietrich wrote on Fri, 04 September 2015 18:11https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TMF&component=Xtext
file_input:
{file_input}
( los+=stmt )*
if_stmt:
test:
suite:
suiteblock:
BEGIN
stmts+=stmt+
END
stmt:
print_stmt:
PRINT vlaue=STRING
terminal STRING:
if true:
print "x"
print "x"
print "y"
There are other problematic parts where new line is required. For instance empty lines at module level throw error right now. Also, for instance decorators require new line
[Updated on: Fri, 04 September 2015 19:07] Report message to a moderator
FUDForum. Page generated in 0.05028 seconds
