OSLC Automation without Maven build- Class Hierarchy inconsistent [message #1707075] |
Wed, 02 September 2015 05:50 |
Abhishek SA Messages: 7 Registered: September 2014 |
Junior Member |
I am trying to implement a OSLC provider with automation specification. I am not using maven setup of OSLC for building the application. Instead, am adding all the required jar files in my project classpath.
The problem am facing here is:
the main entry point class which extends OSLCWinkApplication(in OSLC app), in my case OSLC4JAutomationApplication(PFA screenshots).
Problem 1: in OSLC4JAutomationApplication class, am not able to resolve the "Hierarchy of the type <classname> is inconsistent . I have added the dependent jar file in the build path as well<oslc4j-wink-2.1.0.jar>.
Problem 2: in the same class, I also see a compilation problem which says , required class is indirectly referenced from .class files. Here, I tried all generic solutions on internet like, removing and re-adding the system JRE system library under the project build path etc.
Kindly help.
Abhishek S.A
Image 1>
Image 2>
[Updated on: Wed, 02 September 2015 06:04] Report message to a moderator
FUDForum. Page generated in 0.04346 seconds
