Re: Select Model Element Variable [message #1707821 is a reply to message #1706960] |
Wed, 09 September 2015 14:15 |
Le 01/09/2015 10:04, Tiago Jorge a écrit :
> Hi!
> When creating a new line in a table I am using the 'Select Model Element
> Variable' to pick existing elements of a certain type.
> However, the candidate expression returning the collection of EObject
> is fetching elements from other packages too
> (...eContainer().oclAsType(Package).getModelDependencies().eAllContents()...).
> As a result I am getting elements from different packages with the same
> type and name, which makes it oblivious for me from which package they
> come just by looking at the resulting list.
> Is there a way to show the package from which a candidate element for
> selection comes?
You can configure your 'Select Model Element Variable' to display a tree
by enabling the 'Tree' attribute.
Then the 'Root expression' allows you to choose the elements you want to
see as roots of the tree. And recursively on each root and then each
tree element, the 'Children expression' will be evaluated to compute the
element to display as children.
Note that all the root and children elements must be in the result
collection of 'Candidates expression' to be displayed.
You might find more information in the documentation, see [1] (and [2]).
> Cheers
Maxime - Obeo
[1] See User-Defined Variables in
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#tools_specification
[2]
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#selection_wizard
Maxime Porhel - Obeo
FUDForum. Page generated in 0.02811 seconds
