Equinox servlet bridge invalid code according to Servlet 3.0 specifications [message #1706637] |
Fri, 28 August 2015 10:26 |
Arnaud MERGEY Messages: 243 Registered: March 2010 Location: France |
Since eclipse Mars, it seems servlet bridge is broken for weblogic 12c server.
Trying to deploy any war based application with servlet bridge, the application fails with above stack trace
According to Servlet Spec 3.0,http://download.oracle.com/otn-pub/jcp/servlet-3.0-fr-eval-oth-JSpec/servlet-3_0-final-spec.pdf, section 4.4, it seems servletContext.getServletRegistration can only be called from the contexInitialized method of a ServletContextListener implementation or from the onStartup method of a ServletContainerInitializer.
Currently it is called from the equinox starting background thread
This issue occurs in weblogic but could occurs in other app servers as well if they strictly respect servlet 3 specifications.
Quote:java.lang.UnsupportedOperationException: [HTTP:101388]The ServletContext was passed to the ServletContextListener.contextInitialized method of a ServletContextListener that was neither declared in web.xml or web-fragment.xml, nor annotated with javax.servlet.annotation.WebListener.
at weblogic.servlet.internal.WebAppServletContext.checkNotifyDynamicContext(WebAppServletContext.java:3989)
at weblogic.servlet.internal.WebAppServletContext.getServletRegistration(WebAppServletContext.java:3871)
at org.eclipse.equinox.http.servlet.internal.Activator.getHttpServiceEndpoints(Activator.java:205)
at org.eclipse.equinox.http.servlet.internal.Activator.addingService(Activator.java:109)
at org.eclipse.equinox.http.servlet.internal.Activator.addingService(Activator.java:1)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:482)
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:998)
at org.eclipse.equinox.http.servlet.internal.Activator.addProxyServlet(Activator.java:58)
at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.init(ProxyServlet.java:36)
at org.eclipse.equinox.servletbridge.BridgeServlet.registerServletDelegate(BridgeServlet.java:257)
at org.eclipse.equinox.http.servletbridge.internal.Activator.start(Activator.java:25)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
[Updated on: Fri, 28 August 2015 12:30] Report message to a moderator
FUDForum. Page generated in 0.03618 seconds
