Home » Archived » Eclipse SCADA » How to create an Eclipse project for an OPC DA interface?(Do not know how to create a simple example that communicates with an OPC DA simultor)
How to create an Eclipse project for an OPC DA interface? [message #1706291] Tue, 25 August 2015 09:27
Hello!
I am a consulter and started shortly in a project where we have to use both the OPC DA & the REST API. But in a first step, we decided to install Eclipse SCADA & make a communication with an OPC DA simulator. The first job is to install an Eclipse SCADA project, because SCADA includes both interfaces with pure Java & does not need any OS-specific code/resources like DLLs etc.
On the Web, I found a tutorial, but the page seems to be outdated. The enlisted resources such as this does not exist (anymore).
The error message of eclipse Kepler 4.3, not finding the resource, is:
Error Contacting Site
No software found at http://git.eclipse.org/c/eclipsedata/org.eclipse.scada.base.git.
Do you want to edit the location? [ No ] [ Yes ]
Same for the page at openSCADA, where I get the same error.
My problem is not only this link error. What I need is a simple tutorial that creates an appropriate Eclipse project & communicates with an OPC DA simulator.
What we have done sofar:
  • Installed the Oracle VM VirtualBox Linux Debian to run near to Raspberry Pi
  • Installed the Oracle VM VirtualBox Windows 7 to run the
  • Installed a Windows 7 virtual machine to run the Matrikon OPC Simultor
  • Installed Eclipse Kepler 4.3, a it is said that Eclipse SCADA is running there
  • The Java 1.8 SE & its JDK
Do you know resources (like tutorials) for an OPC DA newbie? I found one on YouTube for a Modbus project, but it is not the one I need.
Thank you in advance!
[Updated on: Tue, 25 August 2015 09:32] by Moderator
Previous Topic:Eclipsescada: importpackage error.
Next Topic:Extending the EclipseMagazine tutorial
Current Time: Sun Nov 09 20:51:53 EST 2025
Powered by FUDForum. Page generated in 0.02744 seconds
