Home » Modeling » EMF » [XCore] Xtext-maven-plugin with xcore lead to exception
[XCore] Xtext-maven-plugin with xcore lead to exception [message #1705483] |
Sun, 16 August 2015 20:47 |
Hi modeling heroes!
I'm creating a tycho/xcore/xtext project, and encounters an issue when mixing xcore and xtext.
While building, I got this exception on my xcore powered project:
[INFO] --- xtext-maven-plugin:2.8.4:generate (default) @ net.osgiliath.modeler.metamodel.class ---
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore:jar:2.10.0-v20130911-20131101.184326-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore:jar:2.10.0-v20140117-20140308.162131-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore:jar:2.10.0-v20140514-20140615.074948-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.common:jar:2.10.0-v20130911-20131101.184418-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.common:jar:2.10.0-v20140117-20140308.162206-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.common:jar:2.10.0-v20140514-20140615.074938-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore.xmi:jar:2.10.0.v20130911-20131101.184401-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore.xmi:jar:2.10.0-v20140117-20140308.162157-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore.xmi:jar:2.10.0-v20140514-20140615.075014-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen:jar:2.9.0-v20130930-20131101.184305-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen:jar:2.10.0-v20140127-20140308.162113-2 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen:jar:2.10.0-v20140519-20140615.074924-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen.ecore:jar:2.10.0-v20130930-20131101.184147-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen.ecore:jar:2.10.0-v20140127-20140308.162034-2 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen.ecore:jar:2.10.0-v20140519-20140615.074844-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[INFO] Encoding: UTF-8
[INFO] Compiler source level: 1.8
[INFO] Compiler target level: 1.8
[INFO] Using common types.
[INFO] Collecting source models.
[INFO] Installing type provider.
[WARNING] Only terminal rules are supported by lexer based converters but got SignedInt which is an instance of ParserRule
java.lang.IllegalArgumentException: Only terminal rules are supported by lexer based converters but got SignedInt which is an instance of ParserRule
at org.eclipse.xtext.conversion.impl.AbstractLexerBasedConverter.setRule(AbstractLexerBasedConverter.java:128)
at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.internalRegisterForClass(AbstractDeclarativeValueConverterService.java:128)
at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.getConverters(AbstractDeclarativeValueConverterService.java:95)
at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.getConverter(AbstractDeclarativeValueConverterService.java:83)
at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.toValue(AbstractDeclarativeValueConverterService.java:74)
at org.eclipse.xtext.parser.DefaultEcoreElementFactory.getTokenValue(DefaultEcoreElementFactory.java:90)
at org.eclipse.xtext.parser.DefaultEcoreElementFactory.set(DefaultEcoreElementFactory.java:69)
at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.set(AbstractInternalAntlrParser.java:319)
at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.set(AbstractInternalAntlrParser.java:326)
at org.eclipse.emf.ecore.xcore.parser.antlr.internal.InternalXcoreParser.ruleXStringToStringMapEntry(InternalXcoreParser.java:871)
at org.eclipse.emf.ecore.xcore.parser.antlr.internal.InternalXcoreParser.ruleXAnnotation(InternalXcoreParser.java:669)
at org.eclipse.emf.ecore.xcore.parser.antlr.internal.InternalXcoreParser.ruleXPackage(InternalXcoreParser.java:286)
at org.eclipse.emf.ecore.xcore.parser.antlr.internal.InternalXcoreParser.entryRuleXPackage(InternalXcoreParser.java:199)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.parse(AbstractInternalAntlrParser.java:541)
at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doParse(AbstractAntlrParser.java:102)
at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.parse(AbstractAntlrParser.java:84)
at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doParse(AbstractAntlrParser.java:62)
at org.eclipse.xtext.parser.AbstractParser.parse(AbstractParser.java:33)
at org.eclipse.xtext.resource.XtextResource.doLoad(XtextResource.java:170)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLoad(LazyLinkingResource.java:101)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.xtext.resource.persistence.StorageAwareResource.load(StorageAwareResource.java:95)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:265)
at org.eclipse.xtext.builder.standalone.StandaloneBuilder.launch(StandaloneBuilder.java:253)
at org.eclipse.xtext.maven.XtextGenerator.internalExecute(XtextGenerator.java:164)
at org.eclipse.xtext.maven.XtextGenerator.execute(XtextGenerator.java:140)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
[INFO] Generating stubs into /Users/charliemordant/git/net.osgiliath.modeler/net.osgiliath.modeler.metamodels/net.osgiliath.modeler.metamodel.class/target/xtext-temp/stubs
[INFO] Compiling stubs located in /Users/charliemordant/git/net.osgiliath.modeler/net.osgiliath.modeler.metamodels/net.osgiliath.modeler.metamodel.class/target/xtext-temp/stubs
[INFO] Installing type provider for stubs.
[INFO] Validate and generate.
[INFO] Starting validation for input: 'class.xcore'
[INFO] Starting generator for input: 'class.xcore'
Here's my xtext-maven-plugin configuration (if it is related):
<plugin>
<groupId>org.eclipse.xtext</groupId>
<artifactId>xtext-maven-plugin</artifactId>
<version>${xtext-version}</version>
<executions>
<execution>
<phase>generate-sources</phase>
<goals>
<goal>generate</goal>
</goals>
</execution>
</executions>
<configuration>
<failOnValidationError>false</failOnValidationError>
<languages>
<language>
<setup>org.eclipse.xtext.ecore.EcoreSupport</setup>
<outputConfigurations>
<outputConfiguration>
<outputDirectory>${project.build.directory}/model-gen</outputDirectory>
</outputConfiguration>
</outputConfigurations>
</language>
<language>
<setup>org.eclipse.emf.codegen.ecore.xtext.GenModelSupport</setup>
</language>
<language>
<setup>org.eclipse.emf.ecore.xcore.XcoreStandaloneSetup</setup>
</language>
</languages>
<sourceRoots>
<root>${project.basedir}/model</root>
</sourceRoots>
</configuration>
<dependencies>
<dependency>
<groupId>org.osgi</groupId>
<artifactId>org.osgi.core</artifactId>
<version>${org.osgi_org.osgi.core.version}</version>
</dependency>
<dependency>
<groupId>org.eclipse.core</groupId>
<artifactId>org.eclipse.core.resources</artifactId>
<version>${org.eclipse.core_org.eclipse.core.resources.version}</version>
</dependency>
<dependency>
<groupId>org.eclipse.text</groupId>
<artifactId>org.eclipse.text</artifactId>
<version>${org.eclipse.text_org.eclipse.text.version}</version>
</dependency>
<dependency>
<groupId>org.eclipse.emf</groupId>
<artifactId>org.eclipse.emf.ecore</artifactId>
<version>${org.eclipse.emf_org.eclipse.emf.ecore.version}</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.codegen.ecore</artifactId>
<version>${org.eclipse.emf_org.eclipse.emf.codegen.ecore.version}</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.codegen.ecore.xtext</artifactId>
<version>${org.eclipse.emf_org.eclipse.emf.codegen.ecore.xtext.version}</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.ecore.xcore.lib</artifactId>
<version>${org.eclipse.emf_org.eclipse.emf.ecore.xcore.lib.version}</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.ecore.xcore</artifactId>
<version>${org.eclipse.emf_org.eclipse.emf.ecore.xcore.version}</version>
</dependency>
<dependency>
<artifactId>org.eclipse.xtext.common.types</artifactId>
<version>${org.eclipse.xtext_org.eclipse.xtext.common.types.version}</version>
</dependency>
<dependency>
<artifactId>org.eclipse.xtext.xbase</artifactId>
<version>${org.eclipse.xtext_org.eclipse.xtext.xbase.version}</version>
</dependency>
<dependency>
<artifactId>org.eclipse.xtext.xbase.lib</artifactId>
</dependency>
</dependencies>
</plugin>
<properties>
<tycho-version>0.23.1</tycho-version>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<org.eclipse.emf_org.eclipse.emf.codegen.ecore.xtext.version>1.1.1</org.eclipse.emf_org.eclipse.emf.codegen.ecore.xtext.version>
<org.eclipse.emf_org.eclipse.emf.ecore.xcore.lib.version>1.1.0</org.eclipse.emf_org.eclipse.emf.ecore.xcore.lib.version>
<org.eclipse.emf_org.eclipse.emf.ecore.xcore.version>1.2.2</org.eclipse.emf_org.eclipse.emf.ecore.xcore.version>
<xtext-version>2.8.4</xtext-version>
<org.osgi_org.osgi.core.version>6.0.0</org.osgi_org.osgi.core.version>
<org.eclipse.core_org.eclipse.core.resources.version>3.7.100</org.eclipse.core_org.eclipse.core.resources.version>
<org.eclipse.text_org.eclipse.text.version>3.5.101</org.eclipse.text_org.eclipse.text.version>
<org.eclipse.emf_org.eclipse.emf.ecore.version>2.10.1</org.eclipse.emf_org.eclipse.emf.ecore.version>
<org.eclipse.emf_org.eclipse.emf.codegen.ecore.version>2.10.1</org.eclipse.emf_org.eclipse.emf.codegen.ecore.version>
<org.eclipse.equinox_org.eclipse.equinox.common.version>3.6.0</org.eclipse.equinox_org.eclipse.equinox.common.version>
<org.eclipse.xtext_org.eclipse.xtext.common.types.version>2.8.4</org.eclipse.xtext_org.eclipse.xtext.common.types.version>
<org.eclipse.xtext_org.eclipse.xtext.xbase.version>2.8.4</org.eclipse.xtext_org.eclipse.xtext.xbase.version>
<parentPropertiesFile>root.properties</parentPropertiesFile>
</properties>
And finally the grammar (fairly simple):
@GenModel(childCreationExtenders="true", copyrightText="Osgiliath All rights reserved", extensibleProviderFactory="true", modelDirectory="/net.osgiliath.modeler.metamodel.class/target/model-gen", editDirectory="/net.osgiliath.modeler.metamodel.class.edit/src/main/java-gen", editorDirectory="/net.osgiliath.modeler.metamodel.class.editor/src/main/java-gen", creationSubmenus="true")
@Ecore(nsURI="http://www.osgiliath.net/metamodels/classes/0.0.1")
package net.osgiliath.modeler.metamodel.classes
class ONamedElement {
String name
class OElements extends ONamedElement {
contains OPackage[] packages
contains OParametrizedClassifier[] parametrizedClassifiers
class OPackage extends ONamedElement {
contains OPackage[] subPackages opposite superPackage
container OPackage superPackage opposite subPackages
contains OClassifier[] classifiers opposite ownerPackage
derived String FQN get
var FQN = name
var OPackage current = superPackage
while (null != current) {
FQN=current.name + "." + FQN
current = current.superPackage
return FQN
class OType extends ONamedElement{
enum VISIBILITY {
public as '+' = 0
protected as '#' = 1
private as '-' = 2
class OVisibilityAble extends OType {
VISIBILITY visibility
class OStaticable extends OType {
boolean isStatic = "false"
class OFinalizable extends OType {
Boolean isFinal = "false"
class OAbstractable {
Boolean isAbstract = "false"
class OClassifier extends OType {
container OPackage ownerPackage opposite classifiers
derived String fQN get
return ownerPackage.FQN + "." + name
op String toString() {
return FQN
class OParameter extends ONamedElement, OFinalizable {
refers OType oType
class OMethod extends ONamedElement, OVisibilityAble, OStaticable, OFinalizable, OAbstractable {
refers OType returnType
contains OParameter[] parameters
class OMethodable extends OClassifier {
contains OMethod[] methods
class OInterface extends OVisibilityAble,OMethodable {
refers OInterface[] extensions
class OAttribute extends OParameter, OVisibilityAble, OStaticable {
class OClass extends OVisibilityAble, OMethodable, OFinalizable, OAbstractable {
refers OInterface[] implements
refers OClass extensions
contains OAttribute[] attributes
class OParametrizedClassifier extends OClassifier {
refers OClassifier classifier
refers OClassifier[] parametrizedClassifiers
I also have a grammar using this xcore model, that throws the same exception when I reference this xcore. But when I export the genmodel then reference it for the grammar, it passes without any issue.
Any idea on this? I looked at eclipse bugs or any other source, but didn't find any similar issue.
Charlie
Re: [XCore] Xtext-maven-plugin with xcore lead to exception [message #1705487 is a reply to message #1705483] |
Mon, 17 August 2015 04:41 |
Ed Merks Messages: 33142 Registered: July 2009 |
Charlie,
This should be fixed in the maintenance stream
http://download.eclipse.org/modeling/emf/emf/updates/2.11.x
On 16/08/2015 10:47 PM, Charlie Mordant wrote:
> Hi modeling heroes!
> ParserRule
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> <plugin>
> <executions>
> <execution>
> <goals>
> </goals>
> </execution>
> </executions>
> <configuration>
> <languages>
> <language>
> </language>
> <language>
> </language>
> <language>
> </language>
> </languages>
> <sourceRoots>
> </sourceRoots>
> </configuration>
> <dependencies>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> </dependencies>
> </plugin>
> <properties>
> </properties>
> String name
> var FQN = name
> } return FQN
> enum VISIBILITY {
> public as '+' = 0
> private as '-' = 2
> return FQN
> refers OType oType
> OAbstractable {
> refers OClass extensions contains OAttribute[] attributes
> Best regards,
> Charlie
Ed Merks
Current Time: Fri Apr 26 13:28:25 GMT 2024
Powered by FUDForum. Page generated in 0.03213 seconds
