Home » Modeling » EMF » [CDO] DBStore and Model Evolution
[CDO] DBStore and Model Evolution [message #1705007] Tue, 11 August 2015 07:51 Go to next message
Hi there.
According to some posts here and bugzilla (https://bugs.eclipse.org/bugs/show_bug.cgi?id=256856) there is currently no way to automatically migrate the database after a model evolution.
Because of that, i decided to try to manually migrate the database. The Steps i took were roughly the following:
* Generate a SQL Database with the old version of the model
* Generate a SQL Database with the new version of the model
* Export the structure of both databases to an SQL file and do a diff.
At this point i noticed that the structural differences between the databases were fairly straightforward (to be fair, my edit of the model was just a little thing). In short, it was one additional table and one additional column. To actually migrate the database i continued as following:
* Create the new Table (with the constraints and indices according to the exported SQL file) and the new Column in the correct table
* Update the namespace of the model in the tables CDO_PACKAGE_INFOS
* Update the binary and the namespace in the Table CDO_PACKAGE_UNITS
* Update the namespace and the entries that changed in the evolution in CDO_EXTERNAL_REFS
After a short test, this seems to work.
But given my limited understanding in the way CDOs DBStore handles the database, there might be something that i overlooked. Is this approach feasible, or is there any reason that it shouldnt work?
Some additional Information:
* The Server runs with the standard DBStore horizontal mapping on a MS SQL Database
* The Database i want to migrate is way to big to migrate it with an export-to-xml and reimport
Greetings,
Samuel Leisering
Re: [CDO] DBStore and Model Evolution [message #1705102 is a reply to message #1705007] Wed, 12 August 2015 03:15 Go to previous messageGo to next message
Hi Samuel,
That sounds like a good approach. The DBStore creates the tables for the deployed packages eagerly, so you shouldn't
miss any schema deltas.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] DBStore and Model Evolution [message #1705117 is a reply to message #1705102] Wed, 12 August 2015 04:42 Go to previous messageGo to next message
Thanks for the reply.
I encountered another problem: If i connect to a server with the old model (with the old namespace), with the new model in my code base the calls to the server just hang. They do not time out or give any response.
The actual call i do is
transaction.getObject(CDOIDUtil.createLong(someId));
As i understand it this should throw some kind of exception that the client does not have the correct model to load that object.
Greetings,
Samuel
Re: [CDO] DBStore and Model Evolution [message #1705123 is a reply to message #1705117] Wed, 12 August 2015 06:09 Go to previous messageGo to next message
Am 12.08.2015 um 10:42 schrieb Samuel Leisering:
> Hi
> The actual call i do is transaction.getObject(CDOIDUtil.createLong(someId));
> that object.
This is not so easily (and reliably) detectable. I vaguely remember that we tried to do that long ago but suffered from
too many false positives. I think it's best to not change a published package's contents. The nsURI should change if the
contents change. And then this should not be a problem anymore.
Cheers
/Eike
Re: [CDO] DBStore and Model Evolution [message #1705131 is a reply to message #1705123] Wed, 12 August 2015 06:43 Go to previous messageGo to next message
It did change, that was the point.
I have two clients. One still has the old model with the old nsUri, the other has the new model with the new nsUri. The model on the server still has the old nsUri. While the old client can connect just fine, the new client just hangs.
I checked the PackageRegistry of the session with session.getPackageRegistry(). this contains the EPackage with the old nsUri, while the generated field MyModelPackage.eNS_URI contains the new nsURI (on the new client)
Greetings
Samuel
Re: [CDO] DBStore and Model Evolution [message #1705184 is a reply to message #1705131] Wed, 12 August 2015 12:14 Go to previous messageGo to next message
Am 12.08.2015 um 12:43 schrieb Samuel Leisering:
Can you see in the debugger why or where it hangs?
Cheers
/Eike
> Greetings
> Samuel
Re: [CDO] DBStore and Model Evolution [message #1705267 is a reply to message #1705184] Thu, 13 August 2015 07:41 Go to previous messageGo to next message
Ok i think i found the problem. I connect to the server with a reconnecting session.
The sessions ExceptionHandler is the org.eclipse.emf.cdo.internal.net4j.RecoveringCDOSessionImpl.RecoveringExceptionHandler.
when i load an object, the method
org.eclipse.emf.internal.cdo.session.DelegatingSessionProtocol.loadRevisions(List<RevisionInfo> infos, CDOBranchPoint branchPoint, int referenceChunk, int prefetchDepth)
is called, which in turn calls loads the revisions on the delegate. The delegate is CDOClientProtocol. In
org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(RequestWithConfirmation<RESULT> request)
the ClientProtocol correctly throws a RuntimeException because the package is not available. The Exception is then caught in the DelegatingSessionProtocol, handled by the RecoveringExceptionHandler, which basically ignores the Exception, and the DelegatingSessionProtocol is stuck in an endless loop in loadRevisions.
Since the ReconnectingCDOSessionConfigurationImpl is restricted and throws an usupported operation exception on setExceptionHandler, there is no straightforward way to set a new ExceptionHandler for the session.
*EDIT*
I tried the same thing with a different ExceptionHandler, and it works.
Greetings,
Samuel
[Updated on: Thu, 13 August 2015 08:11] by Moderator
Re: [CDO] DBStore and Model Evolution [message #1705312 is a reply to message #1705267] Thu, 13 August 2015 12:20 Go to previous message
Am 13.08.2015 um 13:41 schrieb Samuel Leisering:
> Hi
> org.eclipse.emf.cdo.internal.net4j.RecoveringCDOSessionImpl.RecoveringExceptionHandler. when i load an object, the method
I think the problem is in RecoveringCDOSessionImpl.RecoveringExceptionHandler.handleException(), which indeed ignores
the exception unless it's a TransportException. I've added a test case and fixed the problem in:
474919: RecoveringExceptionHandler swallows non-transport exceptions
https://bugs.eclipse.org/bugs/show_bug.cgi?id=474919
Cheers
/Eike
Previous Topic:Persisting chained objects in CDO(MongoDB store)
Next Topic:how to design a drag and drop between to containment references
Current Time: Fri Nov 07 23:56:50 EST 2025
Powered by FUDForum. Page generated in 0.10572 seconds
