Home » Newcomers » Newcomers » [SOLVED] How to remove the panel right to the code? (edit:MINIMAP)(How to set the configuration of windows )
[SOLVED] How to remove the panel right to the code? (edit:MINIMAP) [message #1704191] Sat, 08 August 2015 09:36 Go to next message
Hi everybody, Razz
I've searched in the options but couldn't find the solution to it.
I don't have a lot of space on my monitor and I'm trying to keep only the windows I find the use in my Eclipse setting.
Currently, there's the panel on the right of my code, which shows where I am in my file, with gray lines. I don't use it so I'd prefer to remove it.
A picture is better than words since I don't know the name of this panel:
i.imgur.com/32G55ZL.png?1
How do I remove this panel?
Thanks a lot in advance!
[Updated on: Sat, 08 August 2015 16:24] by Moderator
Re: How to remove the panel right to the code? (don't know its name...) [message #1704204 is a reply to message #1704191] Sat, 08 August 2015 14:45 Go to previous messageGo to next message
On 08/08/2015 10:53 AM, gustav klopp wrote:
> Hi everybody, :p
> it.
http://stackoverflow.com/questions/27713153/whats-the-funny-pane-to-the-right-of-the-pydev-editor-window
Re: How to remove the panel right to the code? (don't know its name...) [message #1704207 is a reply to message #1704204] Sat, 08 August 2015 16:25 Go to previous message
Thanks a lot!
It was difficult to find an answer when I didn't know the name of the thing Razz
But it's solved now!
Previous Topic:How to connect to svn server and compile by another remote machine
Next Topic:Sub-Projects in eclipse
Current Time: Wed Nov 05 15:18:55 EST 2025
Powered by FUDForum. Page generated in 0.09446 seconds
