Home » Archived » Eclipse SmartHome » Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off?
Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1704184] Sat, 08 August 2015 05:30 Go to next message
Hi all,
I am just working on getting some bindings running on a non-Equinox OSGi runtime environment.
I struggled over that the Eclipse SmartHome framework and some bindings (from ESH, from openHAB2, ignoring openHAB1 for the moment) are using different HttpClients. To minimize the footprint over restricted devices (like Raspberry Pi 1) it is a bad idea to use multiple clients at same time, will increase memory footprint and startup time.
I made a rough analysis of the code base:
# bundles using Apache HttpClient 3.x
$ find . -name "MANIFEST.MF" -exec grep -l "org.apache.commons.httpclient" {} \;
./openhab2-master/git/openhab2/addons/binding/org.openhab.binding.autelis/META-INF/MANIFEST.MF
./openhab2-master/git/openhab2/addons/binding/org.openhab.binding.squeezebox/META-INF/MANIFEST.MF
./openhab2-master/git/openhab2/bundles/core/org.openhab.core/META-INF/MANIFEST.MF
./openhab2-master/git/openhab2/bundles/core/org.openhab.core.compat1x/META-INF/MANIFEST.MF
./smarthome-master/git/smarthome/bundles/io/org.eclipse.smarthome.io.net/META-INF/MANIFEST.MF
./smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/META-INF/MANIFEST.MF
# bundles using Apache HttpClient 4.x
$ find . -name "MANIFEST.MF" -exec grep -l "org.apache.http." {} \;
./openhab2-master/git/openhab2/addons/binding/org.openhab.binding.ipp/META-INF/MANIFEST.MF
# bundles using Jetty Client
$ find . -name "MANIFEST.MF" -exec grep -l "org.eclipse.jetty.client" {} \;
./openhab2-master/git/openhab2/addons/binding/org.openhab.binding.avmfritz/META-INF/MANIFEST.MF
I also checked the different footprint of the used http clients:
* Apache HttpClient 3.x: org.apache.commons.httpclient, org.apache.commons.codec (about 600 kB)
* Apache HttpClient 4.x: org.apache.httpcomponents.httpclient, org.apache.httpcomponents.httpcore, org.apache.commons.codec (about 1,5 MB)
* Jetty Client 9.2.x: Jetty Client, Http, IO, Util (about 900 kB)
As HttpClient 3.x is considered as legacy this should be removed long term. So decision would be between Apache HttpClient 4 and Jetty Client. Considering the footprint Jetty would be first choice, but the client libraries might be not so popular like Apache HttpClient.
In general such a change would break the API in one case (HttpUtil.createHttpMethod), but this will not be used until now in ESH, openHAB2 (only 1x used in openHAB1 NEST binding), so no real issue.
What do you think? Is this the effort worth to try to get rid of not needed HttpClients?
Same time new bindings should be asked/enforced to stick on same http client.
Bye, Jochen
Re: Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1704185 is a reply to message #1704184] Sat, 08 August 2015 05:51 Go to previous messageGo to next message
Makes perfect sense to trim the bloat, as long as whatever HTTP client library is chosen allows for manually catching and redirecting 307 codes as the Nest API requires. I would have used just org.openhab.io.net.http.HttpUtil.executeUrl had it not been for this requirement.
Re: Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1704209 is a reply to message #1704185] Sat, 08 August 2015 17:03 Go to previous messageGo to next message
Hi Jochen,
I think we all agree that we should get rid off Apache HttpClient 3 - thanks for highlighting this.
Regarding the question of the best replacement: So far we had documented that Apache HttpClient 4 should be used: https://www.eclipse.org/smarthome/documentation/development/bindings/dependencies.html
But there were reasons why some bindings used the Jetty library instead. I think I just recalled them: What you have missed is that the Apache HttpClient 4 does not support asynchronous processing of requests - you will need an additional component called asyncclient (https://hc.apache.org/httpcomponents-asyncclient-4.1.x/index.html), which ends up at 2MB with all its dependencies. Furthermore, the version 4.1 somehow suggests that it is not very actively maintained (not in sync with the HttpClient 4 at least - the issue tracker shows last activity in February this year: https://issues.apache.org/jira/browse/HTTPASYNC/?selectedTab=com.atlassian.jira.jira-projects-plugin:summary-panel).
The Jetty client seems to be much more active and modern - it e.g. already comes with HTTP/2 support as well and many other features, see https://webtide.com/http2-support-for-httpclient/. I personally have some positive experiences with using this library (asynchronously) and thus would think that it probably would be a good choice. But I would love to hear some other opinions and experiences as well!
Kai
Re: Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1705511 is a reply to message #1704209] Mon, 17 August 2015 05:53 Go to previous messageGo to next message
There are a few bindings-to-be-approved (OH2) that also use an HTTP client in the context of JSON-RPC and REST clients. But they can easily (I hope) be switched over.
K
Re: Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1705743 is a reply to message #1704185] Tue, 18 August 2015 13:51 Go to previous messageGo to next message
John Cocula wrote on Sat, 08 August 2015 05:51
Thanks John for the feedback.
I checked the code you mentioned at https://github.com/openhab/openhab/blob/master/bundles/binding/org.openhab.binding.nest/src/main/java/org/openhab/binding/nest/internal/messages/AbstractRequest.java#L139
Could this be a default implementation in org.openhab.io.net.http.HttpUtil.executeUrl for a HTTP 307 return?
Re: Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1705744 is a reply to message #1704209] Tue, 18 August 2015 13:56 Go to previous messageGo to next message
Hi Kai,
Kai Kreuzer wrote on Sat, 08 August 2015 17:03
These are valid arguments against Apache HttpClient 4.x, I agree. Thanks for pointing to the async stuff missing in my overview.
I agree with you, we should give it a try. I will work on a PR to change org.eclipse.smarthome.io.net to use Jetty.
We have then to revise the recommendations at
https://www.eclipse.org/smarthome/documentation/development/bindings/dependencies.html to move over to Jetty.
Bye, Jochen
Re: Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1705746 is a reply to message #1705511] Tue, 18 August 2015 14:01 Go to previous messageGo to next message
Hi Karel,
karel goderis wrote on Mon, 17 August 2015 05:53
K
good point. I only checked the bindings actually in ESH and openHAB2 master, not any forks/pending PRs.
Maybe we can help with a good sample binding (like avmfritz) how to use Jetty client.
Bye, Jochen
Re: Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1705755 is a reply to message #1705746] Tue, 18 August 2015 16:21 Go to previous messageGo to next message
The Tesla binding uses javax.ws.rs.client (via WebTarget), which is I guess the Jersey client implementation in the end
The Helios binding uses WS-Notification implementation from the Apache CXF library (that is pure SOAP, not clear what http client that is, and no clue how to switch that over)
The HDAnywhere binding relies on org.eclipse.smarthome.io.net.http.HttpUtil
The Miele binding is based on JSON-RPC, implemented via java.net.HttpURLConnection
The ATSAdvanced binding (will not be published due to SDK license constraints) is based on the Apache CXF as well
Re: Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1735343 is a reply to message #1705755] Fri, 17 June 2016 09:24 Go to previous messageGo to next message
I would like to work on this, I have opened an issue in the ESH repo - https://github.com/eclipse/smarthome/issues/1689
[Updated on: Fri, 19 May 2017 10:36] by Moderator
Re: Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? [message #1763777 is a reply to message #1735343] Fri, 19 May 2017 10:39 Go to previous message
The task is finished, for more details please refer to the the issue in the last post.
I think the topic can be closed.
Previous Topic:How to packaging Eclipse smart home with karaf integration
Next Topic:channel: change state pattern dynamically
Current Time: Thu Nov 06 16:59:27 EST 2025
Powered by FUDForum. Page generated in 0.05447 seconds
