Eclipse Mars won't close when telling it to, instead pops up an error about TableViewLabelProvider [message #1703749] |
Tue, 04 August 2015 16:29 |
Chris Boyd Messages: 7 Registered: July 2015 |
Hello all,
I have a copy of eclipse open that, every time I try to close it, instead of closing, it pops up this error:
Here is the stack trace from the workspace/.metadata/.log file:
!ENTRY org.eclipse.ui.workbench 4 2 2015-08-03 11:24:09.106
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/ui/views/markers/internal/TableViewLabelProvider
at org.eclipse.mylyn.ide.ui.AbstractFocusMarkerViewAction.updateMarkerViewLabelProvider(AbstractFocusMarkerViewAction.java:59)
at org.eclipse.mylyn.internal.debug.ui.FocusBreakpointsViewAction.getViewers(FocusBreakpointsViewAction.java:39)
at org.eclipse.mylyn.context.ui.AbstractFocusViewAction$2.preShutdown(AbstractFocusViewAction.java:163)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:949)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.ui.internal.Workbench.firePreShutdown(Workbench.java:946)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.access$21(Workbench.java:1073)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1414)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1411)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1384)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:1571)
at org.eclipse.ui.internal.WorkbenchWindow.access$16(WorkbenchWindow.java:1542)
at org.eclipse.ui.internal.WorkbenchWindow$11.run(WorkbenchWindow.java:1603)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1600)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1614)
at org.eclipse.ui.internal.WorkbenchWindow$6.close(WorkbenchWindow.java:523)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer$7.shellClosed(WBWRenderer.java:518)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1327)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1351)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1336)
at org.eclipse.swt.widgets.Shell.closeWidget(Shell.java:654)
at org.eclipse.swt.widgets.Shell.gtk_delete_event(Shell.java:1272)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1948)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:5590)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4717)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:9272)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1225)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2422)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3428)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
[Updated on: Tue, 04 August 2015 16:31] Report message to a moderator
FUDForum. Page generated in 0.02774 seconds
