Re: Conflict with the component names [message #1703706 is a reply to message #1703684] |
Tue, 04 August 2015 10:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Oliver Goetz![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=oliver.goetz%40bredex.de) Messages: 219 Registered: May 2011 |
is ArgoLineClientV2R4_Text_1_txf the component/logical name (the name you use when you are writing your tests) or is it the technical name (the name the developer gives this component)?
If it is the logical name does it make sense that it has the same name? Is it really the same logical component, i.e. does it fulfill the same functionality? If not I would suggest that these components should have different component names.
What do you mean by saying " I want to extract a word but I can't."
I think that it is not possible to read text from a Graphics Component so this should be the answer why you are not able to "extract a word" from
Component Type -> Graphics Component
Component Name -> ArgoLineClientV2R4_Text_1_txf
Oliver
[Updated on: Tue, 04 August 2015 10:50] Report message to a moderator
Re: Conflict with the component names [message #1703951 is a reply to message #1703864] |
Thu, 06 August 2015 06:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Romain Vianef![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=vianefromain%40live.fr) Messages: 32 Registered: April 2015 |
Member |
Hi Oliver,
sorry but how can I do that with Eclipse ?
My problem is not with the Jubula software because I can interact with the "component" but when I do the same thing using Eclipse, it don't work.
Jubula recognizes the component (in the screenshot) as a Graphics Component and I can use the method selectAll() with.
Under Eclipse, at this step of selection, the method fails. It is what I don't understand.
[Updated on: Thu, 06 August 2015 06:35] Report message to a moderator
Re: Conflict with the component names [message #1703983 is a reply to message #1703969] |
Thu, 06 August 2015 11:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
Hi Alex,
That's it. Sorry if my previous explanation wasn't clear.
First I want to "click" and after "selectAll". When I use the ITE, that's good. And with the Jubula Client API, when I click on the component, the test fails.
With reference to the component, I think it's a text field. For the ITE, it's a Graphics Component (no specification). In the parameters of the application, the component is a field (in reading mode, we can't write in).
And as additional information, we don't have the code source of the application.
Romain
FUDForum. Page generated in 0.04276 seconds
