Create representation error [message #1703153] |
Tue, 28 July 2015 23:04 |
Jim S. Messages: 17 Registered: October 2014 |
I try to create a model and a representation. However, I get an "Could not find a session for model element System[TRANSIENT]" error. This is the code I use for the creation:
final ResourceSet resourceSet = new ResourceSetImpl();
final Resource systemResource = resourceSet.createResource(systemURI);
final System newSystem = SystemFactory.eINSTANCE.createSystem();
newSystem.setEntityName(NEW_SYSTEM_NAME);
systemResource.getContents().add(newSystem);
systemResource.save(Collections.EMPTY_MAP);
progressMonitor.worked(50);
if (representationName != null) {
final URI representationFileURI = URI
.createPlatformResourceURI("/" + systemURI.segment(1) + "/representations.aird", true);
final Session session = SessionManager.INSTANCE.getExistingSession(representationFileURI);
if (session == null) {
throw new RuntimeException("Not a modelling project");
Viewpoint systemViewpoint = null; // FIXME expose with a constant
for (Viewpoint possibleViewpoint : session.getSelectedViewpoints(true)) {
if (ComposedProvidingRequiringEntityEditorConstants.SYSTEM_DESIGN_NAME.equals(possibleViewpoint.getName())) {
systemViewpoint = possibleViewpoint;
break;
if (systemViewpoint == null) { // FIXME expose with a constant
throw new RuntimeException("No suitable Viewpoint is registered");
RepresentationDescription representationDescription = null;
for (RepresentationDescription possibleRepresentationDescription : DialectManager.INSTANCE
.getAvailableRepresentationDescriptions(
Collections
.singleton(systemViewpoint),
newSystem)) {
representationDescription = possibleRepresentationDescription;
break;
if (representationDescription == null) {
throw new RuntimeException("No suitable RepresentationDescription has been found");
DRepresentation representation = DialectManager.INSTANCE.createRepresentation(representationName,
newSystem, representationDescription, session, progressMonitor);
DialectUIManager.INSTANCE.openEditor(session, representation, progressMonitor);
I already searched the forum for solutions but the ones that have been posted did not work for me. Do you know what I am doing wrong?
Re: Create representation error [message #1703180 is a reply to message #1703153] |
Wed, 29 July 2015 07:15 |
Le 29/07/2015 01:04, Jim S. a écrit :
Why do you not use the resource set of your current session ?
Did you already open the session ?
> if
> break;
> Collections
> newSystem)) {
> break;
> progressMonitor);
newSystem comes from the resourceSet created by you and not from the
resourceSet of your session.
> progressMonitor);
Maxime - Obeo
Need professional services for Sirius?
Maxime Porhel - Obeo
Re: Create representation error [message #1703182 is a reply to message #1703180] |
Wed, 29 July 2015 07:25 |
Hi Jim,
>> Hi,
You could use your own resource set to create and populate and save your
resource.
But you have to make sure the session reloaded it.
In a standard environment, the workspace will detect that you modified
the file and Sirius will reload the modified resources for each session
using this file.
>> if
>> break;
>> registered");
>> Collections
>> newSystem)) {
>> break;
>> progressMonitor);
>> progressMonitor);
> Regards
Maxime - Obeo
Re: Create representation error [message #1703215 is a reply to message #1703212] |
Wed, 29 July 2015 12:30 |
Le 29/07/2015 14:14, Jim S. a écrit :
> Thanks for your reply!
> I created my own ResourceSet because I do not know how to access the
> Session`s ResourceSet. For the same reason I don`t know how I can make
> the session reload its ResourceSet.
> I tried opening the Session after retrieving it but that did not change
> the behavior. I was not sure whether the Session was already open since
> I retrieved it from the SessionManager.
If you retrieve it from the SessionManager, this indicates that it exist
and is opened.
Is your modified resource in the workspace ?
Do you have a Modeling Project ? (it will automatically add contained
files as semantic resources if EMF can load them.)
Did you already add your systemResource as semantic resources of the
current session ?
See
org.eclipse.sirius.business.api.session.Session.addSemanticResource(URI,
IProgressMonitor)
> Regards, Jim
Maxime - Obeo
Re: Create representation error [message #1703259 is a reply to message #1703215] |
Wed, 29 July 2015 20:57 |
I tried adding the Resource to the set which required wrapping it in a command. Both did not work. The project I work in is a Modeling Project.
I also refactored the code a bit:
final Session session = SessionManager.INSTANCE.getSession(
URI.createPlatformResourceURI("/" + systemURI.segment(1) + "/representations.aird", true),
monitor);
final TransactionalEditingDomain domain = session.getTransactionalEditingDomain();
monitor.worked(25);
final CreateSystemModelCommand createSystemModelCommand = new CreateSystemModelCommand(domain, systemURI);
domain.getCommandStack().execute(createSystemModelCommand);
final System createdSystem = createSystemModelCommand.getCreatedSystem();
monitor.worked(50);
if (createRepresentation) {
final CreateRepresentationCommand createRepresentationCommand = new CreateRepresentationCommand(session,
Activator.getDefault().COMPOSED_PROVIDING_REQUIRING_ENTITY_DIAGRAM, createdSystem, representationName,
monitor);
domain.getCommandStack().execute(createRepresentationCommand);
final DRepresentation createdRepresentation = createRepresentationCommand.getCreatedRepresentation();
monitor.worked(75);
DialectUIManager.INSTANCE.openEditor(session, createdRepresentation, monitor);
monitor.worked(100);
The execute method of the "CreateSystemModelCommand"
final System system = SystemFactory.eINSTANCE.createSystem();
system.setEntityName(systemURI.segment(systemURI.segmentCount() -1).split("\\.")[0]);
final Resource resource = resourceSet.createResource(systemURI);
resource.getContents().add(system);
try {
resource.save(Collections.EMPTY_MAP);
} catch (IOException e) {
throw new RuntimeException(e);
createdSystem = system;
I now use the session`s resource set (shouldn`t this take care the the resource is available to the session?).
Regards, Jim
[Updated on: Thu, 30 July 2015 16:48] Report message to a moderator
Re: Create representation error [message #1705608 is a reply to message #1703259] |
Mon, 17 August 2015 19:08 |
I still wasn't able to resolve this issue. Does anyone have an idea what I might be doing wrong?
EDIT: I was able to solve the problem:
I had difficulties reproducing it, because while debugging the created resource was added to the session automatically, in a normal environment it was not.
I now use a AddSemanticResourceCommand to make sure the Resource is attached to the Session.
[Updated on: Tue, 18 August 2015 15:57] Report message to a moderator
FUDForum. Page generated in 0.03230 seconds
