Home » Language IDEs » C / C++ IDE (CDT) » Error while installing AVR Eclipse Plugin in Linux(Install)
Error while installing AVR Eclipse Plugin in Linux [message #1702395] Wed, 22 July 2015 02:09 Go to next message
Hello Everyone,
I got the latest lubuntu op system running and already installed Eclipse Platform Version: 3.8.1. I am new to linux and to eclipse too.
My goal is to use eclipse for AVR programming in linux environment. I tried to follow some tutorials. They say to follow these few steps.:
[Help] -> [Install new software] -> [Work with] :site link
After i have added that link eclipse says Could not find that site link
I actually tried another method which worked for me in windows. In Windows I added the content.jar file and could install the AVR plugin. I tried to do the same in linux. However i got the following error:
An error occurred while collecting items to be installed
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Artifact not found: jar:file:/home/kechua/Asztal/AVR%20Eclipse%20Plugin/artifacts.jar!/plugins/de.innot.avreclipse.core_2.4.2.jar. (...)
Is there a way to install AVR Eclipse Plugin in linux?
Re: Error while installing AVR Eclipse Plugin in Linux [message #1702465 is a reply to message #1702395] Wed, 22 July 2015 09:46 Go to previous messageGo to next message
Open your Eclipse, go to
[Help] -> [Eclipse Marketplace] and type AVR into the search box.
Re: Error while installing AVR Eclipse Plugin in Linux [message #1702592 is a reply to message #1702465] Thu, 23 July 2015 08:42 Go to previous messageGo to next message
There's no Eclipse Marketplace in Help.
I found [Help] -> [ Install New Software] -> [WOrk with: (I then selected) Indigo Update Site.: http://download.eclipse.org/releases/indigo/
Checked Application Development Frameworks then searched for 'AVR'. Result: Program freezes. I tried again and got the same result.
Re: Error while installing AVR Eclipse Plugin in Linux [message #1702602 is a reply to message #1702592] Thu, 23 July 2015 09:25 Go to previous messageGo to next message
You should have the Marketplace Client feature installed.
Go to the Install New software, select your Eclipse base repository and look at General Purpose Tools -> Marketplace Client.
(The instructions are for Luna, I do not have older versions at hand).
Install it if it is missing and try again.
You may need to also install the GCC-AVR package from your Linux distribution repository.
Re: Error while installing AVR Eclipse Plugin in Linux [message #1702833 is a reply to message #1702602] Sat, 25 July 2015 09:16 Go to previous message
Thanks a lot it worked.
Previous Topic:Extended Project Explorer view is not refreshing on build
Next Topic:Editor shows "Symbol could not be resolved" although declared
Current Time: Mon Sep 15 02:27:58 EDT 2025
Powered by FUDForum. Page generated in 0.03725 seconds
