Home » Eclipse Projects » Sirius » "new representation" not available to create a diagram(impossible to associate a diagram to a model)
"new representation" not available to create a diagram [message #1702330] Tue, 21 July 2015 11:19 Go to next message
Hi!
I have created a odesign project and a modeling project corresponsding to a meta-model. I can create appropriate instances in my modeling project using EMF model Editor. A viewpoint selection is associated with my modeling project. But it is not possible to access to "new Representation" in order to create a diagram. Only "Control" and "Export diagrams as images" choices are available.
Thanks for your help !
Anne-Lise Courbis
Re: "new representation" not available to create a diagram [message #1702550 is a reply to message #1702330] Thu, 23 July 2015 03:38 Go to previous message
Hi Anne-Lise,
Le 21/07/2015 17:19, anne-Lise Courbis a écrit :
> Hi!
Hi which version of Sirius/Eclipse do you use ?
I understand you have selected your viewpoint on your modeling project.
Which domain class did specify in your diagram description ? The new
representations menu will be available on instances of this domain class.
You can also try the "Create Representation" wizard available in the
contextual menu of the modeling projects
> Anne-Lise Courbis
Maxime - Obeo
Need professional services for Sirius?
Previous Topic:Problem with loading odesign file
Next Topic:CPN editor creation with sirius
Current Time: Sun Nov 09 21:30:52 EST 2025
Powered by FUDForum. Page generated in 0.24227 seconds
