Home » Eclipse Projects » NatTable » Prevent sort column
Prevent sort column [message #1702262] Tue, 21 July 2015 03:43 Go to next message
I want to prevent some of column on nattable. For this I see the SortableGridExample.java. It is ok. And When I implement to prevent some of column sort to TreeGridExample it is not work. I cannot prevent column for sort. The code is below
I registered the NO_SORT_LABEL getCustomComparatorConfiguration and I added nattable configuration but Still column 0 can be sort.
import java.util.Collections;
import java.util.Comparator;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
import org.eclipse.nebula.widgets.nattable.NatTable;
import org.eclipse.nebula.widgets.nattable.config.AbstractRegistryConfiguration;
import org.eclipse.nebula.widgets.nattable.config.CellConfigAttributes;
import org.eclipse.nebula.widgets.nattable.config.ConfigRegistry;
import org.eclipse.nebula.widgets.nattable.config.DefaultComparator;
import org.eclipse.nebula.widgets.nattable.config.DefaultNatTableStyleConfiguration;
import org.eclipse.nebula.widgets.nattable.config.IConfigRegistry;
import org.eclipse.nebula.widgets.nattable.config.IConfiguration;
import org.eclipse.nebula.widgets.nattable.config.NullComparator;
import org.eclipse.nebula.widgets.nattable.data.IColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.data.IDataProvider;
import org.eclipse.nebula.widgets.nattable.data.ReflectiveColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.examples.AbstractNatExample;
import org.eclipse.nebula.widgets.nattable.examples.runner.StandaloneNatExampleRunner;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.DetailGlazedListsEventLayer;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.GlazedListsDataProvider;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.GlazedListsSortModel;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.filterrow.DefaultGlazedListsFilterStrategy;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.tree.GlazedListTreeData;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.tree.GlazedListTreeRowModel;
import org.eclipse.nebula.widgets.nattable.filterrow.FilterIconPainter;
import org.eclipse.nebula.widgets.nattable.filterrow.FilterRowHeaderComposite;
import org.eclipse.nebula.widgets.nattable.filterrow.FilterRowPainter;
import org.eclipse.nebula.widgets.nattable.grid.GridRegion;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultColumnHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultCornerDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultRowHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.layer.ColumnHeaderLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.CornerLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultColumnHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultRowHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.RowHeaderLayer;
import org.eclipse.nebula.widgets.nattable.hideshow.ColumnHideShowLayer;
import org.eclipse.nebula.widgets.nattable.hideshow.RowHideShowLayer;
import org.eclipse.nebula.widgets.nattable.layer.AbstractLayer;
import org.eclipse.nebula.widgets.nattable.layer.DataLayer;
import org.eclipse.nebula.widgets.nattable.layer.cell.ColumnOverrideLabelAccumulator;
import org.eclipse.nebula.widgets.nattable.reorder.ColumnReorderLayer;
import org.eclipse.nebula.widgets.nattable.selection.SelectionLayer;
import org.eclipse.nebula.widgets.nattable.selection.config.RowOnlySelectionBindings;
import org.eclipse.nebula.widgets.nattable.selection.config.RowOnlySelectionConfiguration;
import org.eclipse.nebula.widgets.nattable.sort.ISortModel;
import org.eclipse.nebula.widgets.nattable.sort.SortConfigAttributes;
import org.eclipse.nebula.widgets.nattable.sort.SortHeaderLayer;
import org.eclipse.nebula.widgets.nattable.sort.config.SingleClickSortConfiguration;
import org.eclipse.nebula.widgets.nattable.style.CellStyleAttributes;
import org.eclipse.nebula.widgets.nattable.style.DisplayMode;
import org.eclipse.nebula.widgets.nattable.style.Style;
import org.eclipse.nebula.widgets.nattable.style.theme.ModernNatTableThemeConfiguration;
import org.eclipse.nebula.widgets.nattable.style.theme.ThemeConfiguration;
import org.eclipse.nebula.widgets.nattable.test.fixture.data.RowDataListFixture;
import org.eclipse.nebula.widgets.nattable.tree.ITreeData;
import org.eclipse.nebula.widgets.nattable.tree.SortableTreeComparator;
import org.eclipse.nebula.widgets.nattable.tree.TreeLayer;
import org.eclipse.nebula.widgets.nattable.tree.config.DefaultTreeLayerConfiguration;
import org.eclipse.nebula.widgets.nattable.ui.menu.HeaderMenuConfiguration;
import org.eclipse.nebula.widgets.nattable.ui.menu.PopupMenuBuilder;
import org.eclipse.nebula.widgets.nattable.util.GUIHelper;
import org.eclipse.nebula.widgets.nattable.viewport.ViewportLayer;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import ca.odell.glazedlists.EventList;
import ca.odell.glazedlists.FilterList;
import ca.odell.glazedlists.GlazedLists;
import ca.odell.glazedlists.SortedList;
import ca.odell.glazedlists.TreeList;
public class TreeGridExample extends AbstractNatExample {
    protected static final String NO_SORT_LABEL = "noSortLabel";
        StandaloneNatExampleRunner.run(800, 400, new TreeGridExample());
    public Control createExampleControl(Composite parent) {
        ConfigRegistry configRegistry = new ConfigRegistry();
        configRegistry.registerConfigAttribute(
                SortConfigAttributes.SORT_COMPARATOR, DefaultComparator.getInstance());
        // Underlying data source
        createDatums();
        EventList eventList = GlazedLists.eventList(this.datums.values());
        SortedList sortedList = new SortedList(eventList, null);
        FilterList<Datum> filterList = new FilterList<Datum>(sortedList);
        String[] propertyNames = new String[] { "foo", "bar" };
        IColumnPropertyAccessor columnPropertyAccessor = new ReflectiveColumnPropertyAccessor(
                propertyNames);
        // Column header layer
        IDataProvider columnHeaderDataProvider = new DefaultColumnHeaderDataProvider(
                propertyNames);
        DataLayer columnHeaderDataLayer = new DefaultColumnHeaderDataLayer(
                columnHeaderDataProvider);
        ISortModel sortModel = new GlazedListsSortModel(sortedList,
                columnPropertyAccessor, configRegistry, columnHeaderDataLayer);
        final TreeList treeList = new TreeList(filterList,
                new DatumTreeFormat(sortModel), new DatumExpansionModel());
        GlazedListTreeData treeData = new GlazedListTreeData(treeList);
        GlazedListsDataProvider bodyDataProvider = new GlazedListsDataProvider(
                treeList, columnPropertyAccessor);
        DataLayer bodyDataLayer = new DataLayer(bodyDataProvider);
        // GlazedListsEventLayer glazedListsEventLayer =
        // new GlazedListsEventLayer(bodyDataLayer, treeList);
        DetailGlazedListsEventLayer glazedListsEventLayer = new DetailGlazedListsEventLayer(
        // Body layer
        ColumnReorderLayer columnReorderLayer = new ColumnReorderLayer(
                glazedListsEventLayer);
        ColumnHideShowLayer columnHideShowLayer = new ColumnHideShowLayer(
                columnReorderLayer);
        RowHideShowLayer rowHideShowLayer = new RowHideShowLayer(
                columnHideShowLayer);
        // Switch the ITreeRowModel implementation between using native grid
        // Hide/Show or GlazedList TreeList Hide/Show
        // TreeLayer treeLayer = new TreeLayer(rowHideShowLayer, new
        // TreeRowModel(treeData), true);
                new GlazedListTreeRowModel(treeData), false);
        SelectionLayer selectionLayer = new SelectionLayer(treeLayer);
        ViewportLayer viewportLayer = new ViewportLayer(selectionLayer);
        ColumnHeaderLayer columnHeaderLayer = new ColumnHeaderLayer(
                columnHeaderDataLayer, viewportLayer, selectionLayer);
        // Note: The column header layer is wrapped in a filter row composite.
        // This plugs in the filter row functionality
//        ColumnOverrideLabelAccumulator labelAccumulator = new ColumnOverrideLabelAccumulator(
//                columnHeaderDataLayer);
//        columnHeaderDataLayer.setConfigLabelAccumulator(labelAccumulator);
        // Register labels
        SortHeaderLayer sortHeaderLayer = new SortHeaderLayer(
                columnHeaderLayer, sortModel, false);
        final FilterRowHeaderComposite filterRowHeaderLayer =
                new FilterRowHeaderComposite(
                        new DefaultGlazedListsFilterStrategy(
                        		filterList,
                                configRegistry),
                                sortHeaderLayer,
                        columnHeaderDataLayer.getDataProvider(),
                        configRegistry);
        // Row header layer
        DefaultRowHeaderDataProvider rowHeaderDataProvider = new DefaultRowHeaderDataProvider(
                bodyDataProvider);
        DefaultRowHeaderDataLayer rowHeaderDataLayer = new DefaultRowHeaderDataLayer(
                rowHeaderDataProvider);
        RowHeaderLayer rowHeaderLayer = new RowHeaderLayer(rowHeaderDataLayer,
        // Corner layer
        DefaultCornerDataProvider cornerDataProvider = new DefaultCornerDataProvider(
                columnHeaderDataProvider, rowHeaderDataProvider);
        DataLayer cornerDataLayer = new DataLayer(cornerDataProvider);
        CornerLayer cornerLayer = new CornerLayer(cornerDataLayer,
                rowHeaderLayer, filterRowHeaderLayer);
        // Grid
        GridLayer gridLayer = new GridLayer(viewportLayer, filterRowHeaderLayer,
                rowHeaderLayer, cornerLayer);
        NatTable natTable = new NatTable(parent, gridLayer, false);
        natTable.addConfiguration(new AbstractRegistryConfiguration() {
            public void configureRegistry(IConfigRegistry configRegistry) {
                // Shade the row to be slightly darker than the blue background.
                final Style rowStyle = new Style();
                rowStyle.setAttributeValue(
                        CellStyleAttributes.BACKGROUND_COLOR,
                        GUIHelper.getColor(197, 212, 231));
                        CellConfigAttributes.CELL_STYLE, rowStyle,
                        DisplayMode.NORMAL, GridRegion.FILTER_ROW);
                		CellConfigAttributes.CELL_PAINTER,
   		             new FilterRowPainter(new FilterIconPainter(GUIHelper
   		                     .getImage("filter"))), DisplayMode.NORMAL, GridRegion.FILTER_ROW);
        natTable.setConfigRegistry(configRegistry);
        natTable.addConfiguration(new DefaultNatTableStyleConfiguration());
        natTable.addConfiguration(new HeaderMenuConfiguration(natTable) {
            protected PopupMenuBuilder createRowHeaderMenu(NatTable natTable) {
                return super.createRowHeaderMenu(natTable)
                        .withHideRowMenuItem().withShowAllRowsMenuItem();
        natTable.addConfiguration(new DefaultTreeLayerConfiguration(treeLayer));
        natTable.addConfiguration(new SingleClickSortConfiguration());
        natTable.addConfiguration(getCustomComparatorConfiguration(columnHeaderLayer));
        // Uncomment to see the native tree list printed to stout.
        // printTree(treeList, treeData);
        natTable.configure();
        return natTable;
    private static class DatumTreeFormat implements TreeList.Format<Datum> {
        private final ISortModel sortModel;
        public DatumTreeFormat(ISortModel sortModel) {
            this.sortModel = sortModel;
        public void getPath(List path, Datum element) {
            path.add(element);
            Datum parent = element.getParent();
            while (parent != null) {
                path.add(parent);
                parent = parent.getParent();
            Collections.reverse(path);
        public boolean allowsChildren(Datum element) {
            return true;
        public Comparator getComparator(int depth) {
            return new SortableTreeComparator(
                    GlazedLists.beanPropertyComparator(Datum.class, "foo"),
                    this.sortModel);
    private static class DatumExpansionModel implements
            TreeList.ExpansionModel<Datum> {
        public boolean isExpanded(Datum element, List path) {
            return true;
        public void setExpanded(Datum element, List path,
                boolean expanded) {}
    protected void printTree(TreeList<Datum> treeList, ITreeData treeData) {
        System.out.println(treeList.size());
        for (int i = 0; i < treeList.size(); i++) {
            final Datum location = treeList.get(i);
            final int depth = treeList.depth(i);
            final boolean hasChildren = treeList.hasChildren(i);
            final boolean isExpanded = treeList.isExpanded(i);
            for (int j = 0; j < depth; j++)
                System.out.print("\t");
            if (hasChildren)
                System.out.print(isExpanded ? "- " : "+ ");
            else
                System.out.print("  ");
            System.out.println(location.getFoo());
    public class Datum {
        private final Datum parent;
        private String foo;
        private int bar;
        public Datum(Datum parent, String foo, int bar) {
            this.parent = parent;
            this.foo = foo;
            this.bar = bar;
        public Datum getParent() {
            return this.parent;
        public String getFoo() {
            return this.foo;
        public int getBar() {
            return this.bar;
        public String toString() {
            return "[" + "parent=" + this.parent + ", foo=" + this.foo + ", bar=" + this.bar
    private Map datums = new HashMap();
    private void createDatum(String parent, String foo, int bar) {
        Datum datum = new Datum((Datum) this.datums.get(parent), foo, bar);
        this.datums.put(foo, datum);
    private void createDatums() {
        createDatum(null, "root", 1);
        createDatum("root", "A", 10);
        createDatum("A", "A.1", 100);
        createDatum("A", "A.2", 110);
        createDatum("A", "A.3", 120);
        createDatum("root", "B", 20);
        createDatum("B", "B.1", 200);
        createDatum("B", "B.2", 210);
        createDatum("root", "C", 30);
        createDatum("C", "C.1", 330);
        createDatum("C", "C.2", 370);
        createDatum("C", "C.3", 322);
        createDatum("C", "C.4", 310);
        createDatum("C", "C.5", 315);
        createDatum(null, "root2", 2);
        createDatum("root2", "X", 70);
        createDatum("X", "X.1", 700);
        createDatum("X", "X.2", 710);
        createDatum("X", "X.3", 720);
        createDatum("root2", "Y", 80);
        createDatum("Y", "Y.1", 800);
        createDatum("Y", "Y.2", 810);
        createDatum("root2", "Z", 90);
        createDatum("Z", "Z.1", 900);
        createDatum("Z", "Z.2", 910);
        createDatum("Z", "Z.3", 920);
        createDatum("Z", "Z.4", 930);
        createDatum("Z", "Z.5", 940);
    private IConfiguration getCustomComparatorConfiguration(
            final AbstractLayer columnHeaderDataLayer) {
        return new AbstractRegistryConfiguration() {
                // Add label accumulator
                labelAccumulator
                        .registerColumnOverrides(0,
//                                RowDataListFixture.getColumnIndexOfProperty(RowDataListFixture.ASK_PRICE_PROP_NAME),
                                NO_SORT_LABEL);
                // Register null comparator to disable sort
                configRegistry
                                DefaultComparator.getInstance(), DisplayMode.NORMAL,
                                NO_SORT_LABEL);
Re: Prevent sort column [message #1702265 is a reply to message #1702262] Tue, 21 July 2015 04:38 Go to previous messageGo to next message
If I unterstand this correctly, you try to enable sort on some columns and disable sort on others, am I right?
1. Create a subclass of SortColumnAction and override the run method.
There you can get the columnPosition via ((NatEventData) event.data).getColumnPosition().
Now you have the columnPosition, which you can use for your "proceed" check.
If the column matches, proceed by calling super.run(NatTable natTable, MouseEvent event), else return.
2. Now you have to register your MySpecialSortColumnAction in the UIBindingRegistry.
- First you have to UNREGISTER the current SortColumnAction by calling
uiBindingRegistry.unregisterSingleClickBinding(IMouseEventMatcher mouseEventMatcher)
, with the MouseEventMatcher found in SingleClickSortConfiguration:
- new ColumnHeaderClickEventMatcher(SWT.NONE, 1)
- MouseEventMatcher.columnHeaderLeftClick(SWT.ALT)
- Second you have to REGISTER the new Action (MySpecialSortColumnAction) for the same MouseEventMatcher.
        uiBindingRegistry.registerFirstSingleClickBinding(
                new ColumnHeaderClickEventMatcher(SWT.NONE, 1),
                new MySpecialSortColumnAction(false));
        uiBindingRegistry.registerSingleClickBinding(
                MouseEventMatcher.columnHeaderLeftClick(SWT.ALT),
                new MySpecialSortColumnAction(true));
- You can do this by creating a new AbstractUiBindingConfiguration, e.g. MySpecialSortColumnBindingConfiguration.
- At last you have to ensure, that you add your MySpecialSortColumnBindingConfiguration AFTER the SingleClickSortConfiguration is added. In this way it is ensured, that your configuration will be applied correctly.
Hope that helps, if you have any further questions, please feel free to ask.
André
Re: Prevent sort column [message #1702267 is a reply to message #1702262] Tue, 21 July 2015 04:50 Go to previous messageGo to next message
The reason is that the internal comparators to use by the SortedList are initialized once when creating the TreeList. And at that time the config label is not yet applied. To refresh them afterwards call NatTable#refresh() after NatTable#configure(). This way the cached initialized ComparatorChooser is will be re-created correctly.
Re: Prevent sort column [message #1702268 is a reply to message #1702265] Tue, 21 July 2015 04:54 Go to previous messageGo to next message
Thank you. You are understand my problem correctly.
But In SortableGridExample.java can be done simply. Why is it work in TreeGridExample.java(the implemented code is top). I implemented same code in SortableGridExample to our code?
Re: Prevent sort column [message #1702269 is a reply to message #1702267] Tue, 21 July 2015 04:55 Go to previous messageGo to next message
Oh, and of course you need to correctly copy&paste from one example to the other and use the NullComparator instead of DefaultComparator.getInstance(). Only the NullComparator disables sorting.
Re: Prevent sort column [message #1702270 is a reply to message #1702269] Tue, 21 July 2015 04:59 Go to previous messageGo to next message
Because the SortableGridExample does not contain a TreeList and therefore the initialization of the comparators is done at a later time. In the TreeGridExample the comparators are initialized when creating the new TreeList, and at that time it is not possible to have the configuration applied in NatTable. So in short, it is an issue with GlazedLists creation.
Re: Prevent sort column [message #1806936 is a reply to message #1702265] Sat, 18 May 2019 04:31 Go to previous messageGo to next message
Hello, I try to enable groupby on some columns and disable group on others, what should I do?
Re: Prevent sort column [message #1807182 is a reply to message #1806936] Fri, 24 May 2019 04:36 Go to previous message
There is no built in support for this. You probably need to implement a custom GroupByDragMode that adds such a support.
Please do not hijack forum posts with different topics! This topic was about sorting NOT grouping!
Previous Topic:Vertical scrollbar shifts to the top after user clicks on cell at the bottom
Next Topic:Nattable create cell value
Current Time: Mon Aug 11 04:20:42 EDT 2025
Powered by FUDForum. Page generated in 0.04019 seconds
