Home » Modeling » EMF » [CDO] Logging Commits with a Repository handler
| [CDO] Logging Commits with a Repository handler [message #1701947] |
Fri, 17 July 2015 00:17  |
I am using the latest mars version of CDO to build a server. This
server has a Repository Handler (repository.addHandler(handler);) that
logs changes committed to the repository.
Change logs look similar to output that the
org.eclipse.emf.cdo.common.commit.handler.TextCommitInfoLog produces.
For example here a Person is added to a Location:
2015-07-16 22:49:50,104, [net4j-Thread-3] Commit
com.verticon.cdo.server.provider, INFO,
com.verticon.cdo.server.provider.CommitHandler, Committed CommitInfo[,
<1 addition, 1 change>, CommitData[newObjects=1, changedObjects=1,
detachedObjects=0]]]
+ Person@_2FsM0Cw2EeWbAoAY83zZjw:0v1
name = Mikey
tag = null
alternateId = null
comments = null
description = null
parent = null
longitude = null
events = []
latitude = null
altitude = null
altitudeMode = null
children = []
type = null
* Location@_PO1bkCtzEeWN-IAY83zZjw:0v6 uri=_PO1bkCtzEeWN-IAY83zZjw
children = CDOFeatureDelta[children, ADD,
value=_2FsM0Cw2EeWbAoAY83zZjw, index=1]
And here the same person's name was changed from Mikey to Mikey Mouse:
2015-07-16 23:01:41,923, [net4j-Thread-4] Commit
<1 change>, CommitData[newObjects=0, changedObjects=1, detachedObjects=0]]]
* Person@_2FsM0Cw2EeWbAoAY83zZjw:0v1 uri=_2FsM0Cw2EeWbAoAY83zZjw
name = CDOFeatureDelta[name, SET, value=Mikey Mouse,
oldValue=UNSPECIFIED]
Questions:
1. Since we can have more than one resource open on a repo, for all
adds, removes and changes committed I would like to log which resource
on my repository has had the commit. I can get to the CDOURI, but I need
to see the Resource uri. How can I get this from the ITransaction or
the IStoreAccessor.CommitContext that is passed into my handler?
2. In the case commit of a change as in the second example above, why
does a CDOFeatureDelta not show the oldValue but shows
oldValue=UNSPECIFIED? I would expect the second log message above to
have the output:
CDOFeatureDelta[name, SET, value=Mikey Mouse, oldValue=Mikey]
Anyway to get the old value?
thanks for any help on this,
John
| Re: [CDO] Logging Commits with a Repository handler [message #1701952 is a reply to message #1701947] |
Fri, 17 July 2015 01:41   |
Hi John,
There are two ways:
1) The fast and low-level way is to work only with the CDORevisions that are on the server. In contrast to EObjects you
cannot directly navigate references of CDORevisions because they're represented as CDOIDs. So you need a
CDORevisionProvider to map the CDOIDs of target objects to their respective CDORevisions.
1.1) If you want to navigate through already committed data you could use "new
ManagedRevisionProvider(IRepository.getRevisionManager(), commitInfo)". The commitInfo determines the CDOBranchPoint,
which is always equal to IRepository.getBranchManager().getMainBranch().getHead() unless your repository uses auditing
or branching.
1.2) If you want to navigate over uncommitted data a good candidate is "new
CDOChangeSetDataRevisionProvider(IRepository.getRevisionManager(), commitInfo)". Here the commitInfo not only specifies
the CDOBranchPoint but also provides the needed CDOChangeSetData to compute the post-commit state on the fly.
These two methods will also be handy if you're only interested in resource paths:
CDORevisionUtil.getResourceNodePath(CDOID, CDORevisionProvider)
CDORevisionUtil.getResourceNodePath(CDORevision, CDORevisionProvider)
2) The more convenient but slightly heavier way is to open a ServerCDOView with one of the following methods:
CDOServerUtil.openView(ISession, CDOBranchPoint, CDORevisionProvider)
CDOServerUtil.openView(ISession, CDOBranchPoint)
CDOServerUtil.openView(IView)
CDOServerUtil.openView(CommitContext)
The returned CDOView provides you with simple read access to a navigable EObject graph similar to the client side.
Cheers
/Eike
http://www.esc-net.de
Am 17.07.2015 um 06:17 schrieb John E. Conlon:
> I am using the latest mars version of CDO to build a server. This server has a Repository Handler
> (repository.addHandler(handler);) that logs changes committed to the repository.
> Change logs look similar to output that the org.eclipse.emf.cdo.common.commit.handler.TextCommitInfoLog produces.
> 2015-07-16 22:49:50,104, [net4j-Thread-3] Commit com.verticon.cdo.server.provider, INFO,
> com.verticon.cdo.server.provider.CommitHandler, Committed CommitInfo[, <1 addition, 1 change>,
> CommitData[newObjects=1, changedObjects=1, detachedObjects=0]]]
> name = Mikey
> tag = null
> alternateId = null
> comments = null
> description = null
> parent = null
> longitude = null
> events = []
> latitude = null
> altitude = null
> altitudeMode = null
> children = []
> type = null
> children = CDOFeatureDelta[children, ADD, value=_2FsM0Cw2EeWbAoAY83zZjw, index=1]
> 2015-07-16 23:01:41,923, [net4j-Thread-4] Commit com.verticon.cdo.server.provider, INFO,
> com.verticon.cdo.server.provider.CommitHandler, Committed CommitInfo[, <1 change>, CommitData[newObjects=0,
> name = CDOFeatureDelta[name, SET, value=Mikey Mouse, oldValue=UNSPECIFIED]
> Questions:
> 1. Since we can have more than one resource open on a repo, for all adds, removes and changes committed I would like
> to log which resource on my repository has had the commit. I can get to the CDOURI, but I need to see the Resource
> uri. How can I get this from the ITransaction or the IStoreAccessor.CommitContext that is passed into my handler?
> 2. In the case commit of a change as in the second example above, why does a CDOFeatureDelta not show the oldValue but
> shows oldValue=UNSPECIFIED? I would expect the second log message above to have the output:
> John
| Re: [CDO] Logging Commits with a Repository handler [message #1702044 is a reply to message #1701952] |
Fri, 17 July 2015 16:30   |
Hi Eike,
Thanks that was very helpful.
> resource paths:
I used both of these to retrieve the nodes information for my log
entries. (I also see that Transaction is also a CDORevisionProvider.)
For Adds:
String path = CDORevisionUtil.getResourceNodePath(cdoRevision, transaction);
buffer.append(MessageFormat.format(
" + {0} resource={1}{2}", cdoRevision,
transaction.getRepository().getName(), path)).append('\n');
For Changes:
CDOID id = delta.getID();
CDORevision cdoRevision = transaction.getRevision(id);
String path = CDORevisionUtil.getResourceNodePath(id, transaction);
" * {0} resource={1}{2}", cdoRevision,
Which outputs logs like:
2015-07-17 14:57:49,942, [net4j-Thread-4] Commit
+ PersonType@_GGEM0Cy-EeWbAoAY83zZjw:0v1 resource=repo1/resource1
nameLabel = null
tagLabel = null
alternateIdLabel = null
commentsLabel = null
descriptionLabel = null
longitudeLabel = null
latitudeLabel = null
altitudeLabel = null
altitudeModeLabel = null
name = null
childrenTypes = []
lastNameLabel = null
* Admin@_iCAXQBaZEeWMkYoAJwAAAA:0v9 resource=repo1/resource1
categories = CDOFeatureDelta[categories, ADD,
value=_GGEM0Cy-EeWbAoAY83zZjw, index=4]
Only minor issue I now have is with deletes. Here are two log messages.
The first is before the commit and the second is after:
2015-07-17 14:56:30,096, [net4j-Thread-3] Commit
com.verticon.cdo.server.provider, DEBUG,
com.verticon.cdo.server.provider.CommitHandler, Before Commit
CommitInfo[, <1 change, 1 removal>, CommitData[newObjects=0,
changedObjects=1, detachedObjects=1]]]
* Admin@_iCAXQBaZEeWMkYoAJwAAAA:0v7 resource=repo1/resource1
categories = CDOFeatureDelta[categories, REMOVE, value=UNKNOWN,
index=4]
- ItemType@_9hIUQCsxEeWUeIAY83zZjw:0v3 resource=repo1/resource1
2015-07-17 14:56:30,148, [net4j-Thread-3] Commit
<1 change, 1 removal>, CommitData[newObjects=0, changedObjects=1,
* Admin@_iCAXQBaZEeWMkYoAJwAAAA:0v8 resource=repo1/resource1
index=4]
- null
Note the last line in the second log message - CDORevision is null after
the commit.
Here is the code that generates them:
if (afterCommit) {
buffer.append(" - ").append(cdoRevision).append('\n');
} else {
" - {0} resource={1}{2}", cdoRevision,
I have to treat the before and after condition differently because I
cant get a nodePath after the commit either. As shown above the
cdoRevision from the transaction (CDORevisionProvider) also is null
after the commit.
Yes, I know I just deleted the node. But is there a way to get Revision
and nodePath 'After the Commit' of a detached object?
best regards,
John
On 07/17/2015 12:41 AM, Eike Stepper wrote:
> Hi John,
> There are two ways:
> are on the server. In contrast to EObjects you cannot directly navigate
> need a CDORevisionProvider to map the CDOIDs of target objects to their
> use "new ManagedRevisionProvider(IRepository.getRevisionManager(),
> commitInfo)". The commitInfo determines the CDOBranchPoint, which is
> unless your repository uses auditing or branching.
> "new CDOChangeSetDataRevisionProvider(IRepository.getRevisionManager(),
> commitInfo)". Here the commitInfo not only specifies the CDOBranchPoint
> state on the fly.
> resource paths:
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> name = Mikey
>> tag = null
>> alternateId = null
>> comments = null
>> description = null
>> parent = null
>> longitude = null
>> events = []
>> latitude = null
>> altitude = null
>> altitudeMode = null
>> children = []
>> type = null
>> Questions:
>> need to see the Resource uri. How can I get this from the
>> my handler?
>> have the output:
>> John
| Re: [CDO] Logging Commits with a Repository handler [message #1702055 is a reply to message #1702044] |
Sat, 18 July 2015 02:21   |
Am 17.07.2015 um 22:30 schrieb John E. Conlon:
> Only minor issue I now have is with deletes. Here are two log messages. The first is before the commit and the second
> is after:
> 2015-07-17 14:56:30,096, [net4j-Thread-3] Commit com.verticon.cdo.server.provider, DEBUG,
> com.verticon.cdo.server.provider.CommitHandler, Before Commit CommitInfo[, <1 change, 1 removal>,
> CommitData[newObjects=0, changedObjects=1, detachedObjects=1]]]
> categories = CDOFeatureDelta[categories, REMOVE, value=UNKNOWN, index=4]
> 2015-07-17 14:56:30,148, [net4j-Thread-3] Commit com.verticon.cdo.server.provider, INFO,
> com.verticon.cdo.server.provider.CommitHandler, Committed CommitInfo[, <1 change, 1 removal>, CommitData[newObjects=0,
> - null
> Note the last line in the second log message - CDORevision is null after the commit.
> if (afterCommit) {
How do you determine afterCommit? Via IRepository.WriteAccessHandler.handleTransactionBeforeCommitting() ?
> } else {
> I have to treat the before and after condition differently because I cant get a nodePath after the commit either. As
> shown above the cdoRevision from the transaction (CDORevisionProvider) also is null after the commit.
> Yes, I know I just deleted the node. But is there a way to get Revision and nodePath 'After the Commit' of a detached
> object?
I think your handleTransactionBeforeCommitting() should remember all values that you'll need in
handleTransactionAfterCommitted() and can't compute there (anymore).
Cheers
/Eike
| Re: [CDO] Logging Commits with a Repository handler [message #1702081 is a reply to message #1702055] |
Sat, 18 July 2015 23:59  |
>> messages. The first is before the commit and the second is after:
>> index=4]
>> index=4]
>> - null
>> after the commit.
>> if (afterCommit) {
Yes -
handleTransactionBeforeCommitting is set false,
handleTransactionAfterCommitted is set true.
>> } else {
>> after the commit.
>> Revision and nodePath 'After the Commit' of a detached object?
> values that you'll need in handleTransactionAfterCommitted() and can't
I was thinking I could do that, but wanted to see if I missed something
to prevent me keeping state.
Thanks Eike!
Current Time: Mon Nov 10 05:25:02 EST 2025
Powered by FUDForum. Page generated in 0.57712 seconds
