Home » Language IDEs » ServerTools (WTP) » Xerces Validation Issues with Honour All schema Locations(Schema Validation Issue)
Xerces Validation Issues with Honour All schema Locations [message #1701928] Thu, 16 July 2015 14:30
Way back in 2009/2010 there was a bug - 284272 - that was never updated with Xerces information about validation. We have a similar issue in Luna and Mars with the WTP validation framework (with Xerxes at the center) and I'm wondering if it's due to Xerces 2.9 or something else.
I'm not a savvy XSD guy, but the issues detailed in 284272 still occur for us with certain schema combinations. We're encountering it specifically with the JBoss/SwitchYard project and the SCA schemas we extend for the SwitchYard runtime.
The following error is displayed in the Problems tab:
cvc-complex-type.2.4.a: Invalid content was found starting with element 'sca:interface.java'. One of '{"http://docs.oasis-open.org/ns/opencsa/sca/200912":documentation, "http://docs.oasis-open.org/ns/opencsa/sca/200912":interface, "http://docs.oasis-open.org/ns/opencsa/sca/200912":binding, "http://docs.oasis-open.org/ns/opencsa/sca/200912":callback, "http://docs.oasis-open.org/ns/opencsa/sca/200912":requires, "http://docs.oasis-open.org/ns/opencsa/sca/200912":policySetAttachment, "http://docs.oasis-open.org/ns/opencsa/sca/200912":extensions}' is expected. switchyard.xml src/main/resources/META-INF line 7 XML Problem
Can someone revisit 284272 and let me know if this is indeed a Xerxes issue under the covers with the example included in the bug? It's not our example, but has the same general problem.
I just don't want to open a duplicate of 284272 without knowing more about how the Honour All Schema Locations stuff works under the covers and if it is indeed caused by Xerces - indeed if it might be fixed by an update to Xerces further down the line (they're up to 2.11 and there was a 2.9.1 it looks like we might be able to more simply move to if it's fixed there).
Thanks all!
--Fitz
Previous Topic:Publish Creates Jars With No Resources
Next Topic:Deploy 'gradle war' output.
Current Time: Sun Oct 26 02:01:06 EDT 2025
Powered by FUDForum. Page generated in 0.03033 seconds
