Home » Archived » Gyrex » what's the correct eclipse version shall I use for gyrex 1.3.2?
Re: what's the correct eclipse version shall I use for gyrex 1.3.2? [message #1701697 is a reply to message #1701483] |
Wed, 15 July 2015 02:21   |
Still cannot work according to your target file. And I got following error while starting the target:
!SESSION 2015-07-15 14:17:26.273 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_79
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN
Command-line arguments: -dev file:C:/Users/sean-desktop/workspace/.metadata/.plugins/org.eclipse.pde.core/OSGi Framework/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog -console
!ENTRY org.apache.solr.client.solrj 4 0 2015-07-15 14:17:27.124
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.apache.solr.client.solrj [61]
Unresolved requirement: Import-Package: org.apache.commons.httpclient; version="3.1.0"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.apache.solr.core 4 0 2015-07-15 14:17:27.126
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.apache.solr.core [62]
Unresolved requirement: Import-Package: org.apache.commons.csv; version="[1.0.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.apache.commons.httpclient; version="[3.1.0,4.0.0)"
osgi> 14:17:27,661 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback.groovy]
14:17:27,661 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback-test.xml]
14:17:27,661 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback.xml]
14:17:27,662 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Setting up default configuration.
14:17:27,701 |-INFO in class org.eclipse.gyrex.boot.internal.logback.LogbackConfigurator - Setting up Gyrex log configuration.
14:17:27,701 |-INFO in class org.eclipse.gyrex.boot.internal.logback.LogbackConfigurator - Using built-in default configuration. Enhancements and suggestions welcome.
14:17:27,702 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating DEBUG level on Logger[ROOT] onto the JUL framework
14:17:27,707 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[error-log] - Active log file name: D:\Tools\eclipse\workspace\logs\error.log
14:17:27,707 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[error-log] - File property is set to [D:\Tools\eclipse\workspace\logs\error.log]
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating WARN level on Logger[org.apache.commons] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating WARN level on Logger[httpclient.wire] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating WARN level on Logger[org.apache.http] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating WARN level on Logger[org.apache.zookeeper] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating WARN level on Logger[org.apache.solr] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating WARN level on Logger[org.apache.sshd] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating WARN level on Logger[org.apache.mina] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating WARN level on Logger[org.mortbay.log] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating INFO level on Logger[org.eclipse.jetty] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating INFO level on Logger[org.quartz] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating INFO level on Logger[sun] onto the JUL framework
14:17:27,709 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@5d643630 - Propagating INFO level on Logger[com.google.inject] onto the JUL framework
14:17:27,710 |-INFO in org.eclipse.gyrex.boot.internal.logback.LogbackLevelDebugOptionsBridge@63e66ad5 - Initializing log level overrides.
14:17:27.713 [Start Level: Equinox Container: 60db152a-b92a-0015-1da9-e612a23bc8e9] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_portOffset/gyrex.portOffset, using default value null
14:17:27.776 [Worker-0] INFO org.eclipse.jetty.util.log - Logging initialized @1608ms
14:17:27.783 [Worker-0] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_admin_secure/gyrex.admin.secure, using default value false
14:17:27.796 [Worker-0] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_admin_http_port/gyrex.admin.http.port, using default value 3110
14:17:28.707 [Component Resolve Thread] INFO o.e.g.cloud.internal.CloudActivator - Node id: sean-desktop-pc_53ca934f
14:17:28.761 [Worker-0] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_admin_auth/gyrex.admin.auth, using default value null
14:17:28.761 [Worker-0] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_admin_secure/gyrex.admin.secure, using default value false
14:17:28.823 [Worker-0] INFO org.eclipse.jetty.server.Server - jetty-9.2.9.v20150224
14:17:28.861 [Worker-0] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@dccc9b5{/,file:/D:/Tools/eclipse/workspace/.metadata/.plugins/org.eclipse.gyrex.admin.ui/context/,AVAILABLE}
14:17:28.885 [Component Resolve Thread] INFO o.e.g.e.w.i.WebsocketEventTransport - Activating WebsocketEventTransport.
14:17:28.885 [Component Resolve Thread] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_event_websocket_port/gyrex.event.websocket.port, using default value 3111
14:17:28.896 [Worker-0] INFO o.e.jetty.server.ServerConnector - Started ServerConnector@5d938a38{HTTP/1.1}{0.0.0.0:3110}
14:17:28.896 [Worker-0] INFO org.eclipse.jetty.server.Server - Started @2728ms
14:17:29.663 [Component Resolve Thread] INFO org.eclipse.jetty.server.Server - jetty-9.2.9.v20150224
14:17:29.669 [Component Resolve Thread] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.h.ContextHandler@16e3f7a2{/eventbus,null,AVAILABLE}
14:17:29.676 [Component Resolve Thread] INFO o.e.jetty.server.ServerConnector - Started ServerConnector@5725a222{HTTP/1.1}{0.0.0.0:3111}
14:17:29.676 [Component Resolve Thread] INFO org.eclipse.jetty.server.Server - Started @3508ms
14:17:29.679 [Worker-1] DEBUG o.e.g.e.w.i.WebsocketEventTransport - Connecting online nodes for the event transport.
14:17:29.693 [Worker-1] WARN o.e.g.e.w.i.WebsocketEventTransport - An error occured while connecting online nodes for the event transport. Operation will be retried.
!ENTRY org.eclipse.gyrex.http.jersey 4 0 2015-07-15 14:17:29.742
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.gyrex.http.jersey [159]
Unresolved requirement: Import-Package: org.eclipse.persistence.jaxb.rs; version="[2.4.0,3.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.objectweb.asm; version="[3.1.0,4.0.0)"
14:17:29.742 [Start Level: Equinox Container: 60db152a-b92a-0015-1da9-e612a23bc8e9] INFO o.e.g.h.l.internal.HttpLogActivator - Adding Wildfire Appender...
!ENTRY org.eclipse.gyrex.persistence.solr 4 0 2015-07-15 14:17:30.101
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.gyrex.persistence.solr [174]
Unresolved requirement: Import-Package: org.apache.solr.client.solrj; version="1.4.0"
-> Export-Package: org.apache.solr.client.solrj; bundle-version="3.5.0.v20150506-0844"; bundle-symbolic-name="org.apache.solr.client.solrj"; version="3.5.0"; uses:="org.apache.solr.client.solrj.response, org.apache.solr.client.solrj.beans, org.apache.solr.common.params, org.apache.solr.common, org.apache.solr.common.util"
!ENTRY org.eclipse.gyrex.search 4 0 2015-07-15 14:17:30.112
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.gyrex.search [177]
!ENTRY org.eclipse.jetty.annotations 4 0 2015-07-15 14:17:30.117
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.annotations [180]
Unresolved requirement: Import-Package: org.objectweb.asm; version="4.0.0"
14:17:30.125 [Start Level: Equinox Container: 60db152a-b92a-0015-1da9-e612a23bc8e9] WARN o.e.j.o.b.i.s.DefaultJettyAtJettyHomeHelper - No default jetty created.
!ENTRY org.eclipse.jetty.websocket.javax.websocket.server 4 0 2015-07-15 14:17:30.253
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.websocket.javax.websocket.server [235]
Unresolved requirement: Require-Capability: osgi.extender; filter:="(osgi.extender=osgi.serviceloader.registrar)"
Andreas Mihm wrote on Mon, 13 July 2015 15:34Hi Sean,
sorry, the turoial is not correctly working,
I'll attach a target platform file , which should work. It's quite independend from the eclipse version you use,
Andreas
Re: what's the correct eclipse version shall I use for gyrex 1.3.2? [message #1701754 is a reply to message #1701711] |
Wed, 15 July 2015 08:06   |
Hi Gunnar,
Many thanks for your help.
Now I can started the dev environment now. While, I got an error when I try to access the cluster management page in the web console (http://localhost:3110).
The screenshot for the error is attached. And the detail log while starting the environment is as below:
osgi> 19:58:24,679 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback.groovy]
19:58:24,679 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback-test.xml]
19:58:24,679 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback.xml]
19:58:24,680 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Setting up default configuration.
19:58:24,719 |-INFO in class org.eclipse.gyrex.boot.internal.logback.LogbackConfigurator - Setting up Gyrex log configuration.
19:58:24,720 |-INFO in class org.eclipse.gyrex.boot.internal.logback.LogbackConfigurator - Using built-in default configuration. Enhancements and suggestions welcome.
19:58:24,721 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating DEBUG level on Logger[ROOT] onto the JUL framework
19:58:24,725 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[error-log] - Active log file name: D:\Tools\eclipse\workspace\logs\error.log
19:58:24,725 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[error-log] - File property is set to [D:\Tools\eclipse\workspace\logs\error.log]
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating WARN level on Logger[org.apache.commons] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating WARN level on Logger[httpclient.wire] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating WARN level on Logger[org.apache.http] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating WARN level on Logger[org.apache.zookeeper] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating WARN level on Logger[org.apache.solr] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating WARN level on Logger[org.apache.sshd] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating WARN level on Logger[org.apache.mina] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating WARN level on Logger[org.mortbay.log] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating INFO level on Logger[org.eclipse.jetty] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating INFO level on Logger[org.quartz] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating INFO level on Logger[sun] onto the JUL framework
19:58:24,726 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@516f5228 - Propagating INFO level on Logger[com.google.inject] onto the JUL framework
19:58:24,727 |-INFO in org.eclipse.gyrex.boot.internal.logback.LogbackLevelDebugOptionsBridge@4c6bcaef - Initializing log level overrides.
19:58:24.729 [Start Level: Equinox Container: e0ee93ca-e82a-0015-12a1-8f2f63b87f29] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_portOffset/gyrex.portOffset, using default value null
19:58:24.852 [Worker-0] INFO org.eclipse.jetty.util.log - Logging initialized @3177ms
19:58:24.860 [Worker-0] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_admin_secure/gyrex.admin.secure, using default value false
19:58:24.879 [Worker-0] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_admin_http_port/gyrex.admin.http.port, using default value 3110
19:58:25.807 [Worker-0] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_admin_auth/gyrex.admin.auth, using default value null
19:58:25.807 [Worker-0] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_admin_secure/gyrex.admin.secure, using default value false
19:58:25.809 [Worker-0] INFO org.eclipse.jetty.server.Server - jetty-9.2.9.v20150224
19:58:25.836 [Worker-0] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@7c3aa90a{/,file:/D:/Tools/eclipse/workspace/.metadata/.plugins/org.eclipse.gyrex.admin.ui/context/,AVAILABLE}
19:58:25.854 [Worker-0] INFO o.e.jetty.server.ServerConnector - Started ServerConnector@2e89630{HTTP/1.1}{0.0.0.0:3110}
19:58:25.854 [Worker-0] INFO org.eclipse.jetty.server.Server - Started @4179ms
19:58:25.926 [Component Resolve Thread] INFO o.e.g.cloud.internal.CloudActivator - Node id: sean-desktop-pc_53ca934f
19:58:25.992 [Component Resolve Thread] INFO o.e.g.e.w.i.WebsocketEventTransport - Activating WebsocketEventTransport.
19:58:25.992 [Component Resolve Thread] DEBUG o.e.g.server.settings.SystemSetting - No value set for gyrex_event_websocket_port/gyrex.event.websocket.port, using default value 3111
19:58:26.663 [Component Resolve Thread] INFO org.eclipse.jetty.server.Server - jetty-9.2.9.v20150224
19:58:26.666 [Component Resolve Thread] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.h.ContextHandler@55989874{/eventbus,null,AVAILABLE}
19:58:26.669 [Component Resolve Thread] INFO o.e.jetty.server.ServerConnector - Started ServerConnector@5060706b{HTTP/1.1}{0.0.0.0:3111}
19:58:26.670 [Component Resolve Thread] INFO org.eclipse.jetty.server.Server - Started @4995ms
19:58:26.673 [Worker-1] DEBUG o.e.g.e.w.i.WebsocketEventTransport - Connecting online nodes for the event transport.
19:58:26.681 [Worker-1] WARN o.e.g.e.w.i.WebsocketEventTransport - An error occured while connecting online nodes for the event transport. Operation will be retried.
19:58:26.702 [Start Level: Equinox Container: e0ee93ca-e82a-0015-12a1-8f2f63b87f29] INFO o.e.g.h.l.internal.HttpLogActivator - Adding Wildfire Appender...
19:58:52.747 [qtp1611116091-61] ERROR org.eclipse.gyrex.rap.JFaceLog - Unable to open page 'Cluster (id cluster)'. Please check the server logs.
java.lang.RuntimeException: Error reading list of nodes. GateDownException: ZooKeeper Gate is DOWN. (null)
at org.eclipse.gyrex.cloud.internal.admin.CloudManagerImpl.getOnlineNodes(CloudManagerImpl.java:164) ~[na:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.7.0_79]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.7.0_79]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.7.0_79]
at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.7.0_79]
at org.eclipse.gyrex.common.internal.services.ServiceProxy.invoke(ServiceProxy.java:303) ~[org.eclipse.gyrex.common_1.3.0.v20140923-0741.jar:na]
at com.sun.proxy.$Proxy2.getOnlineNodes(Unknown Source) ~[na:na]
at org.eclipse.gyrex.admin.ui.cloud.internal.NodeBrowserContentProvider.getElements(NodeBrowserContentProvider.java:108) ~[na:na]
at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(StructuredViewer.java:992) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(ColumnViewer.java:699) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1333) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:391) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildren(StructuredViewer.java:900) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:602) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:802) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66) ~[org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:779) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:644) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:750) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(AbstractTreeViewer.java:1495) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewer.java:833) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractTreeViewer.java:1479) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1427) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:403) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1388) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1472) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.gyrex.admin.ui.internal.widgets.FilteredTree$NotifyingTreeViewer.inputChanged(FilteredTree.java:105) ~[na:na]
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:280) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1674) ~[org.eclipse.rap.jface_3.0.0.20150520-1729.jar:na]
at org.eclipse.gyrex.admin.ui.internal.widgets.AdminPageWithTree.activate(AdminPageWithTree.java:141) ~[na:na]
at org.eclipse.gyrex.admin.ui.cloud.internal.ZooKeeperBasedAdminPage.activate(ZooKeeperBasedAdminPage.java:69) ~[na:na]
at org.eclipse.gyrex.rap.application.RapApplicationEntryPoint.activate(RapApplicationEntryPoint.java:170) [org.eclipse.gyrex.rap_1.0.0.v20150604-1242.jar:na]
at org.eclipse.gyrex.rap.application.RapApplicationEntryPoint.open(RapApplicationEntryPoint.java:528) [org.eclipse.gyrex.rap_1.0.0.v20150604-1242.jar:na]
at org.eclipse.gyrex.rap.application.RapApplicationEntryPoint.access$0(RapApplicationEntryPoint.java:513) [org.eclipse.gyrex.rap_1.0.0.v20150604-1242.jar:na]
at org.eclipse.gyrex.rap.application.RapApplicationEntryPoint$4.openPage(RapApplicationEntryPoint.java:401) [org.eclipse.gyrex.rap_1.0.0.v20150604-1242.jar:na]
at org.eclipse.gyrex.rap.application.NavigationBar$1.openPage(NavigationBar.java:61) [org.eclipse.gyrex.rap_1.0.0.v20150604-1242.jar:na]
at org.eclipse.gyrex.rap.application.DropDownNavigation$1.widgetSelected(DropDownNavigation.java:67) [org.eclipse.gyrex.rap_1.0.0.v20150604-1242.jar:na]
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:262) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:708) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:610) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.swt.widgets.Display.executeNextEvent(Display.java:1216) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1197) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.swt.widgets.Display.safeReadAndDispatch(Display.java:1180) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1172) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.lifecycle.ProcessAction.execute(ProcessAction.java:27) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.lifecycle.PhaseExecutor.execute(PhaseExecutor.java:38) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.lifecycle.SimpleLifeCycle.execute(SimpleLifeCycle.java:46) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.service.RWTMessageHandler.executeLifeCycle(RWTMessageHandler.java:56) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.service.RWTMessageHandler.handleMessage(RWTMessageHandler.java:40) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.remote.MessageChainElement.handleMessage(MessageChainElement.java:28) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.processMessage(LifeCycleServiceHandler.java:140) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.processUIRequest(LifeCycleServiceHandler.java:111) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.synchronizedService(LifeCycleServiceHandler.java:81) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.service(LifeCycleServiceHandler.java:72) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.engine.RWTServlet.handleValidRequest(RWTServlet.java:135) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.engine.RWTServlet.handleRequest(RWTServlet.java:117) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at org.eclipse.rap.rwt.engine.RWTServlet.doPost(RWTServlet.java:107) [org.eclipse.rap.rwt_3.0.0.20150601-1556.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) [javax.servlet_3.1.0.v201410161800.jar:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [javax.servlet_3.1.0.v201410161800.jar:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808) [org.eclipse.jetty.servlet_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587) [org.eclipse.jetty.servlet_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:221) [org.eclipse.jetty.server_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127) [org.eclipse.jetty.server_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515) [org.eclipse.jetty.servlet_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [org.eclipse.jetty.server_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061) [org.eclipse.jetty.server_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [org.eclipse.jetty.server_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97) [org.eclipse.jetty.server_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.server.Server.handle(Server.java:497) [org.eclipse.jetty.server_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310) [org.eclipse.jetty.server_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257) [org.eclipse.jetty.server_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540) [org.eclipse.jetty.io_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635) [org.eclipse.jetty.util_9.2.9.v20150224.jar:9.2.9.v20150224]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555) [org.eclipse.jetty.util_9.2.9.v20150224.jar:9.2.9.v20150224]
at java.lang.Thread.run(Unknown Source) [na:1.7.0_79]
Caused by: org.eclipse.gyrex.cloud.internal.zk.GateDownException: ZooKeeper Gate is DOWN. (null)
at org.eclipse.gyrex.cloud.internal.zk.ZooKeeperGate.get(ZooKeeperGate.java:137) ~[na:na]
at org.eclipse.gyrex.cloud.internal.admin.CloudManagerImpl.getOnlineNodes(CloudManagerImpl.java:156) ~[na:na]
... 75 common frames omitted
20:00:26.683 [Worker-1] DEBUG o.e.g.e.w.i.WebsocketEventTransport - Connecting online nodes for the event transport.
20:00:26.685 [Worker-1] WARN o.e.g.e.w.i.WebsocketEventTransport - An error occured while connecting online nodes for the event transport. Operation will be retried.
20:02:26.735 [Worker-0] DEBUG o.e.g.e.w.i.WebsocketEventTransport - Connecting online nodes for the event transport.
20:02:26.736 [Worker-0] WARN o.e.g.e.w.i.WebsocketEventTransport - An error occured while connecting online nodes for the event transport. Operation will be retried.
20:04:26.786 [Worker-0] DEBUG o.e.g.e.w.i.WebsocketEventTransport - Connecting online nodes for the event transport.
20:04:26.788 [Worker-0] WARN o.e.g.e.w.i.WebsocketEventTransport - An error occured while connecting online nodes for the event transport. Operation will be retried.
Re: what's the correct eclipse version shall I use for gyrex 1.3.2? [message #1702299 is a reply to message #1702297] |
Tue, 21 July 2015 08:40  |
I just realized ... this is javax.websocket.server bundle. It can be
ignored and is not required by Gyrex.
Can you post a setup of your launch configuration? For some reason it
looks like it's trying to start all bundles. That shouldn't be
necessary.
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
Current Time: Sat May 24 20:02:41 EDT 2025
Powered by FUDForum. Page generated in 0.05789 seconds
