Home » Eclipse Projects » Eclipse 4 » EModelService doesn't find the menu item
EModelService doesn't find the menu item [message #1700700] Mon, 06 July 2015 10:27 Go to next message
Maybe I'm doing it wrong, but I cannot retreive menu items from the EModelService.
I'm using Mars (4.5) with Build id: I20150528-0700
The code I used is : List<MHandledMenuItem> itemsMenu = modelService.findElements(app, null, MHandledMenuItem.class, null);
This is correct with the MHandledToolItem, in this case the method returns all the tool item. But with MHandledMenuItem I get 0 item.
Am I doing it wrong ? Or this is a bug ?
Re: EModelService doesn't find the menu item [message #1700908 is a reply to message #1700700] Wed, 08 July 2015 02:58 Go to previous messageGo to next message
Contrary to what it seems to be, the constant EModelService.ANYWHERE doesn't search anywhere so I added EModelService.IN_MAIN_MENU to EModelService.ANYWHERE which give the line below
List<MHandledItem> items = modelService.findElements(app, null, MHandledItem.class, tags, EModelService.ANYWHERE | EModelService.IN_MAIN_MENU);
So, now it search anywhere
Re: EModelService doesn't find the menu item [message #1751112 is a reply to message #1700908] Wed, 04 January 2017 09:50 Go to previous message
Thanks Loic, that was useful!
I had a similar issue while looking for a MDirectMenuItem, and I also had to add the EModelService.IN_PART to the findElements() call.
Previous Topic:CycleViewHandler with E4 Parts & E3 Editors in the EditorArea
Next Topic:How to get Application Model updated when making a project copy?
Current Time: Sat Nov 08 21:18:29 EST 2025
Powered by FUDForum. Page generated in 0.24429 seconds
