Home » Eclipse Projects » NatTable » Simple DataLayer filtering
Simple DataLayer filtering [message #1700336] Wed, 01 July 2015 21:38 Go to next message
I'm attempting to setup a simple static filter on a list, with the existing DataLayer implementation as
rowDataLayer = new SpanningDataLayer(getRowDataProvider()); // getRowDataProvider() returns ISpanningDataProvider
Could someone point me in the right direction please? After looking through the examples, I've come up with the following replacement, although I'm getting null pointer exceptions - I'm probably misunderstanding something simple.
//create a new ConfigRegistry which will be needed for GlazedLists handling
ConfigRegistry configRegistry = new ConfigRegistry();
CompositeMatcherEditor<String> autoFilterMatcherEditor = new CompositeMatcherEditor<String>();
DefaultGlazedListsStaticFilterStrategy<String> filterStrategy = new DefaultGlazedListsStaticFilterStrategy<String>(autoFilterMatcherEditor, null, configRegistry);
filterStrategy.addStaticFilter(new Matcher<String>() {
	public boolean matches(String item) {
		return true; // for testing - match everything for now
rowDataLayer = new FilterRowDataLayer<String>(filterStrategy, rowDataLayer, getRowDataProvider(), configRegistry);
Re: Simple DataLayer filtering [message #1700450 is a reply to message #1700336] Thu, 02 July 2015 12:14 Go to previous messageGo to next message
You are passing null for the necessary column accessor. Without that the filter is not able to access the column values of row objects.
Re: Simple DataLayer filtering [message #1700453 is a reply to message #1700450] Thu, 02 July 2015 12:20 Go to previous message
For simple cases you can also give the AbstractFilterListDataProvider a try.
http://download.eclipse.org/nattable/releases/1.0.0/apidocs/org/eclipse/nebula/widgets/nattable/data/AbstractFilterListDataProvider.html
But note that it doesn't scale well with big data sets.
Previous Topic:Preserve Selection On Sorting
Next Topic:Is searching supported?
Current Time: Wed Nov 05 19:01:23 EST 2025
Powered by FUDForum. Page generated in 0.02738 seconds
