Home » Newcomers » Newcomers » Failed Start Up(Eclipse is asking for which work bench and immediately is closed out after )
Failed Start Up [message #1700160] Tue, 30 June 2015 09:08 Go to next message
I read that if eclipse isn't opening properly, in the config file you must put in:
-vm
C:\Program Files\Java\jre7\bin
But now it is starting, getting to the workbench screen, accepting, then closing out. What would be the best way to fix this issue?
-JK
Re: Failed Start Up [message #1700188 is a reply to message #1700160] Tue, 30 June 2015 10:49 Go to previous messageGo to next message
Brief pointers on what to try next can be found in the sticky post: https://www.eclipse.org/forums/index.php/t/198527/
Re: Failed Start Up [message #1700258 is a reply to message #1700160] Wed, 01 July 2015 05:45 Go to previous messageGo to next message
Am 30.06.2015 um 15:09 schrieb James Koch:
> -vm
The new Eclipse Installer would do that automatically for you: http://www.eclipse.org/downloads/installer.php
Cheers
/Eike
http://www.esc-net.de
Re: Failed Start Up [message #1702966 is a reply to message #1700258] Mon, 27 July 2015 11:18 Go to previous message
You do not have "java" in your PATH value. Search on Google "How to add Java to your PATH value"
Previous Topic:Creating a popup menu
Next Topic:Status 404 with BuildJ2EEWebApp WTP tutorial
Current Time: Thu Jun 19 06:30:04 EDT 2025
Powered by FUDForum. Page generated in 0.27633 seconds
