Re: Targlet cannot be resolved [message #1700038 is a reply to message #1699878] |
Mon, 29 June 2015 18:53 |
Am 29.06.2015 um 14:50 schrieb Martin Theiss:
> I have a project, where i depend on the feature "org.eclipse.epp.package.jee.feature.feature.group" from the repository "http://download.eclipse.org/releases/mars".
> During execution of the Targlets task, I get exceptions like
> ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred while installing the items
> at org.eclipse.oomph.targlets.internal.core.TargletContainer.forceUpdate(TargletContainer.java:661)
> at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl$4.run(TargletTaskImpl.java:994)
> at org.eclipse.oomph.util.pde.TargetPlatformUtil.runWithTargetPlatformService(TargetPlatformUtil.java:125)
> at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl.perform(TargletTaskImpl.java:912)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:2906)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:2865)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:3950)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2241)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:3944)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:3942)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2856)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2831)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2762)
> at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:542)
> at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:627)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=C__Users_mtheiss_eclipse_oomph-master_ws-75d773e9cd216a824b3b3e6d379b5df838da1d9e, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]org.eclipse.oomph.gitbash 1.1.0.v20150628-121041, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction).
> ERROR: org.eclipse.equinox.p2.touchpoint.eclipse code=0 Installable unit contains no artifacts: [R]org.eclipse.oomph.gitbash 1.1.0.v20150628-121041.
Is that the exact exception from your project model or the one from your attempt to reproduce with Oomph's?
It's questionable whether the milestone repos all still exist. In Oomph.setup we've changed to just the release train
and Orbit a few days ago.
Cheers
/Eike
http://www.esc-net.de
> It can be reproduced, when you add the requirement and repository to the Oomph project setup file.
> This happens also for other epp package features.
Cheers
/Eike
Re: Targlet cannot be resolved [message #1700568 is a reply to message #1700328] |
Fri, 03 July 2015 19:30 |
Ed Merks Messages: 33216 Registered: July 2009 |
Martin,
Sorry, your question slipped through the cracks...
I wonder if this isn't a problem caused by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=470900
I tried to reproduce your problem but couldn't. So you could try
deleting your cache as described in that bug. If the problem persists,
please open a bugzilla with details for reproducing it.
On 01/07/2015 11:09 PM, Martin Theiss wrote:
> Quote:
> This is the attempt to reproduce it with Oomph's Model.
> Quote:
> The error still happens with all epp package features. If I add the
> features of an epp package directly (and miss the product defining
> feature of it), it is working.
> The problem must have something to do with that exact feature, plugins
> of that feature or p2 configuration. I think EPP has some p2.inf files
> to modify the content.xml further.
> Regards
> Martin
Ed Merks
FUDForum. Page generated in 0.04860 seconds
