Home » Modeling » QVT-OML » objectsOfType problem in Mars release
objectsOfType problem in Mars release [message #1699844] Sat, 27 June 2015 01:49
The new Mars release of QVTo anticipates removal of an inconsistency in
the use of "kind"/"type" between OCL and QVTo.
A new Model::objectsOfKInd method is introduced with the same
functionality as the old objectsOfType; it returns objects of the same
and derived classes. This is consistent with oclIsKindOf.
Unfortunately the new objectsOfType is now consistent with oclIsTypeOf;
it returns only objects of the same type. This is incompatible with
earlier QVTo releases and may lead to your transformations malfunctioning.
Workaround pending a resolution of [1]; recode you objectsOfType calls
as objectsOfKind.
Apologies for the inconvenience.
Ed Willink
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=471170
Previous Topic:Run qvto transformation
Next Topic:[QVTo] Mapping that needs to modify initial Model
Current Time: Fri Nov 07 23:56:48 EST 2025
Powered by FUDForum. Page generated in 0.06324 seconds
