Re: [Texo] Annotation of EReference with no cascades [message #1702867 is a reply to message #1699432] |
Sun, 26 July 2015 23:07 |
Hi Cur,
Hmm I missed your post. In any case I published a new build just now which should solve this problem. Let me know if it
stills occurs.
gr. Martin
On 24-06-15 11:52, Mr Cur wrote:
> I want to annotate an EReference such that no cascades are generated.
> I have a class with a reference to itself. When an instance refers to itself (via some other instance), this results in
> an exception when merge() on the same instance is applied twice.
> This happens because the generated JPA code for the class has the cascade.merge (amongst others) annotation for the
> EReference.
> So, I want to remove this JPA annotation, preferably by an texo annotation model.
> Here is what I did:
> in the annotation model:
> - added annotation for the EReference
> - added an ORM annotation
> - added a many-to-many annotation
> - added cascade type annotation
> - added empty type cascade annotation
> However the annotation editor returns then with following error:
> An error has occurred. See error log for more details.
> The string resource '_UI_cascadeDetach' could not be located
> The resulting annotation looks as follows:
> <eReferenceAnnotations xsi:type="ormannotations:EReferenceORMAnnotation">
> <manyToMany>
> <cascade>
> <cascadeDetach/>
> </cascade>
> </manyToMany>
> </eReferenceAnnotations>
> Generation of JPA classes also results in an error.
> Help is appreciated.
> Cur
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Annotation of EReference with no cascades [message #1703607 is a reply to message #1703139] |
Mon, 03 August 2015 15:07 |
Hi Cur,
A mistake, I published a new build which solves this. The detach cascade type was not handled correctly. I solved this
also. If you don't want cascade you should create a cascadetype node without cascades inside it.
gr. Martin
On 28-07-15 22:10, Mr Cur wrote:
> Hi Martin,
> Thanks for the update.
> I experience still a problem with the code generation.
> With the following annotation for a bi-directional JPA relation:
> <manyToMany mappedBy="myrelation">
> <cascade>
> <cascadeDetach/>
> </cascade>
> </manyToMany>
> the following code is generated:
> @javax.persistence.ManyToMany(, mappedBy="myrelation")
> which does not compile (due to the ',');
> Btw: the inverse relation (with no mappedBy annotion) generates:
> @javax.persistence.ManyToMany()
> which seems to be ok.
> Thanks.
> -- Cur
The Netherlands
FUDForum. Page generated in 0.02971 seconds
