| l10n files generate a gitignore file ? [message #1699269] |
Tue, 23 June 2015 03:54  |
I've noticed that while generating java and properties files from a l10n file, a gitignore file is also created, listing all generated files.
I understand this can be a feature for some, but in my case this is quite disturbing, as it make my Hudson builds (which use the remote git repository) fail.
So I always have to manually find and delete this gitignore file.
Not that much work, but still... Is there any way I can turn off the generation of this gitignore file ?
Thanks for any hints,
Thomas Elskens
| Re: l10n files generate a gitignore file ? [message #1699360 is a reply to message #1699273] |
Tue, 23 June 2015 11:19  |
Yes you are right : preferences > Team > Git > Projects : possibility to uncheck 'Automatically ignore derived resources by adding them to .gitignore'.
Sorry for the trouble, I was thinking it had something to do with the settings of efxclipse.
Thomas
FUDForum. Page generated in 0.26233 seconds
