Home » Eclipse Projects » Oomph » Importing setup fails
Importing setup fails [message #1698700] Wed, 17 June 2015 06:57 Go to next message
I want to import a setup project into the Eclipse installer, but I always get the error message that the file does not contain a valid project.
My setup-file is attached.
I use 1.1.0 Build 1448.
Edit: I just tried to import http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/Oomph.setup but this fails with the same error message.
[Updated on: Wed, 17 June 2015 06:59] by Moderator
Re: Importing setup fails [message #1698702 is a reply to message #1698700] Wed, 17 June 2015 07:07 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=iso-8859-15"
http-equiv="Content-Type">
</head>
Am 17.06.2015 um 12:57 schrieb Oliver Libutzki:<br>
<blockquote cite="mid:mlrjql$qc8$1@xxxxxxxxe.org" type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
Maybe a file encoding problem? When I open it I see this:<br>
<br>
<img src="https://www.eclipse.org/forums/index.php?t=getfile&amp;id=22199" alt=""><br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
</body>
</html>
  • Attachment: hbffjfde.png
    (Size: 32.82KB, Downloaded 161 times)
Re: Importing setup fails [message #1698704 is a reply to message #1698702] Wed, 17 June 2015 07:19 Go to previous messageGo to next message
Eike Stepper wrote on Wed, 17 June 2015 07:07
Cheers
/Eike
Hmm, that's strange. I just double-checked that it's a valid UTF-8 file. So I don't that the issue is encoding related.
Re: Importing setup fails [message #1698951 is a reply to message #1698704] Fri, 19 June 2015 03:21 Go to previous messageGo to next message
the attached setup looks like the empty project setup from my Oomph Playground. Have you tried importing by adding https://raw.githubusercontent.com/nittka/oomph-playground/master/setups/setups/emptyProject.setup to the project catalog? Because this usually worked for me...
Re: Importing setup fails [message #1698957 is a reply to message #1698951] Fri, 19 June 2015 03:51 Go to previous messageGo to next message
Alexander,
I can drag that that link directly from Thunderbird and drop it into
either project catalog. If I've dropped it into one project catalog, I
can no longer drop it into another; it can be contained by at most one
container. So perhaps you've already added it somewhere and are
trying to add it somewhere else and that definitely won't work.
On 19/06/2015 9:21 AM, Alexander Nittka wrote:
Re: Importing setup fails [message #1698962 is a reply to message #1698951] Fri, 19 June 2015 04:02 Go to previous messageGo to next message
Same error message. Any ideas? I'm confused.
Re: Importing setup fails [message #1698970 is a reply to message #1698962] Fri, 19 June 2015 04:46 Go to previous messageGo to next message
I notice the message says does not contain a valid "product". And
indeed what you're saying you're trying to add isn't a Product, it's a
Project. So it seems you're trying to do this on the Product page when
no doubt you want to be doing it on the Project page. Right?
Re: Importing setup fails [message #1698977 is a reply to message #1698970] Fri, 19 June 2015 05:18 Go to previous messageGo to next message
Thanks, I just read some docs to clearify what "product" and "project" means in the Oomph context.
So there seems to be no corresponding wizard, right? I just can select "Setup Project Model" and "WorkingSets Model". But I need a "Product Model" first, right?
Re: Importing setup fails [message #1699005 is a reply to message #1698977] Fri, 19 June 2015 08:24 Go to previous message
Oliver,
Sorry, no, there's no wizard for creating a new Product. Here's an
example you can copy and paste as a starting point.
http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/OomphInstaller.setup
The normal Setup Editor can edit any type of thing. You can of course
also look at the Products in the org.eclipse.products.setup catalog to
copy and paste starting point for your own product definition.
Previous Topic:Heads Up: Installer might not restart automatically after the next self-update
Next Topic:How to reuse Source Locator for a custom Task
Current Time: Sat Nov 08 22:04:25 EST 2025
Powered by FUDForum. Page generated in 0.03976 seconds
